WARNING!! ZDX Lug wrench can break!
Alpha Geek
Please be careful if you have to use your ZDX lug nut wrench! Mine broke today when I was rotating my tires! It snapped where the two rectangular holes are for cranking the wheel down from where it's stored, and where you hook it to the piece for cranking the jack up. It's definitely a weak point where the those two holes are....just a heads up to be careful when you use it! I was using it exactly as I should and it just snapped.
Alpha Geek
Irrelevant, it broke at the end where you insert to crank, not at the nut cup end. I bought a new wrench, and I was using my floor jack. I hope I don't have to crank the spare done...it looks like a real pain to do.
