Removing the taillight
I am trying to remove my taillight so I can change out a blow bulb, but I can’t get off I look through the manual removed the cover took out the two screw, but I can’t get the damn thing to come out.
yeah the service manual is NO HELP. You might try some wd-40 after a little bit of prying. shoot it towards the pins shown the in the manual. mostly the corners.
With the help of a coworker I was able to get off. The first one was a fighter the second one came off easier.
Originally Posted by micellison71
(Post 16423977)
Tailight
It helps if you have a thin plastic body tool and stick under light , if not under you will crack lenses.
Carecarekiosk.com see where he puts the tool and it will come right out |
Originally Posted by kevin barbee
(Post 16426261)
(Post 16426263)
Well I broke my lense ! Prying with tool but wasn’t under assembly. Man I screamed when a chunk broke and fell to ground. I glued it back but plan to replace it.
(Post 16426823)
Hey everyone. I made a couple tutorial videos on how to remove the rear taillights and trunk reverse taillights. Check it out.
(Post 16426536)
Thanks I replace the bulbs with LED, so I hope I don’t have to go and changes them again. That is the one thing I was worrying about was breaking the lens. I started to take it to a shop, but most places won’t change them unless you buy the part from them
Remove brake light bulb(s)?
Has anyone removed/replaced a burned out brake light bulb, the ones in the center of the hatch? I replaced a taillight bulb and noticed a couple of the center bulbs were not lighting up. I couldn’t find anything on YouTube. Any help would be appreciated!
Third center brake light
Hi, The third brake light also called “High Mount Stop Lamp” is mounted onto the rear spoiler. I remember it being LED. The light is sealed and the complete assembly is usually changed when led bulbs stop working. I remember changing out my spoiler wing to the larger OEM spoiler and it required removing the center brake light and transferring it over to the new spoiler. If I remember correctly, once you remove the lip spoiler, there are 2 screws holding the third brake light to the spoiler.
Acura ZDX part number: 34270-SZN-A02 and 34270-SZN-A01 https://cimg9.ibsrv.net/gimg/acurazi...c4b265fc4.jpeg #2 - High mount stop lamp Removing the spoiler is tricky. You have to remove your trunk interior panels to access the spoiler bolts from the inside of the trunk. Here’s a video on how to remove the interior trunk panels. This should help you get access to the spoiler bolts. |
