does 295/30/20 wheel/tire fit?
Anyone one here running a staggered with 295/30/22 rear? I'm wondering if they fit the rear of the rear of our Z without any rubbing
Wow, staggered Z would be a bomb
rubbing usually happens only in the front when steering. rear shouldnt be a problem
I run 295/35r21 all around and no rubbing anywhere. but you gotta pick the proper offset
my 21х10 custom rims are completely flush with fenders otherwise I bet it would rub
That offset may work, what's the width of the wheel? I can tell you if i have that info since i have the offset. Also I wouldn't recommend staggering on an AWD vehicle. Why not go with the same size all around?
If you pick the right tire size with almost equal actual diameter it should be safe
for R22 it should be 255/35-22 front and 295/30-22 rear. that way diameter difference is 0,2%
BUT considering that ZDX AWD is primarily front wheel drive
staggered setup will hardly give any benefit other than nice outlook
Thank you both. As I mentioned above, the set I'm planning on picking up is 265/35/22 all around. They are asanti in chrome which I'm not too crazy about. I plan to have them painted black since i can get them at a great price. Will post pics in a few days.
Its really hard to tell without a width size on the wheel itself. You mention the tire size but doesn't mean much since a 9"-10" wheel can run a 265 tire. I would guess the rim is either 9-9.5 depending on the tire size you have given us. If you can find the actual wheel width I will be able to tell how they will fit.
i got the wheels back to my garage. I tried one on the front wheel and it didn't rub the fender but it's very very close gap. Honestly I don't even know what's the width size of the wheels and the seller didn't have a clue either since he was selling them for a friend. Is there a way to tell on the inside of the wheel?
The staggered style is just for the look on the Z. I put 20's with 8.5 width size on the front and 10 on the rear. With 275/45/20 Front and rear 295/45/20 with + 42 offset. Very good looking, they are flush to fender and like 1/2 inch wider on the rear, have half a inch too on the total diameter from front to back so you dont see it. i can't tell if i love it because a just got them yesterday lol. I know its a little bit bigger than 3% its like +3,4% but they fit right they dont rub and its look good !
emailnatec
29
09-28-2018 04:27 PM
