2024 Acura ZDX Technical Service Bulletins
Old May 3, 2024 | 08:10 AM
EE4Life's Avatar
Forum Contributor
2024 Acura ZDX Technical Service Bulletins:
TSB 24-024 - 2024 ZDX: TQI Information
Applies To: 2024 ZDX - Type S (AWD)
2024 ZDX - A-Spec (RWD/AWD)
http://www.urvi.net/forumfiles/SB/B24-024.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-024.PDF
TSB 24-042 - Service Manual Update: Sunroof/Sunshade Motor Initialization
Applies To: 2024 ZDX - ALL
http://www.urvi.net/forumfiles/SB/B24-042.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-042.PDF
TSB 24-050 - Safety Recall: 2024 ZDX EBCM Software Update
Applies To: 2024 ZDX - ALL except 2WD models - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-050.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-050.PDF
TSB 25-005 - Product Update: Electric Parking Brake (EPB) Harness Rubbing Half-Shaft Boot
Applies To: 2024 ZDX - ALL - Check iN VIN Status
http://www.urvi.net/forumfiles/SB/B25-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-005.PDF
TSB 25-013 - Safety Recall: 2024 ZDX Passenger-Side Front Stabilizer Bracket Bolt Inspection
Applies To: 2024 ZDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B25-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-013.PDF
TSB 25-016 - Product Update: 2024 ZDX Multi-View Display Reversed
Applies To: 2024 ZDX - Type-S - ALL
http://www.urvi.net/forumfiles/SB/B25-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-016.PDF
TSB 25-022 - Service High Voltage Message B2BAA
Applies To: 2024 ZDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B25-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-022.PDF
TSB 25-024 - Safety Recall: 2024 ZDX Passenger-Side Front Stabilizer Bracket Bolt Inspection
http://www.urvi.net/forumfiles/SB/B25-024.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-024.PDF
TSB 25-025 - MIL Illuminated or Service High Voltage Message Displayed on Instrument Panel; Potential 12-Volt Battery Discharge
http://www.urvi.net/forumfiles/SB/B25-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-025.PDF
TSB 25-033 - A11 Radio Control Module Software Updates #1
http://www.urvi.net/forumfiles/SB/B25-033.PDF
http://techinfo.honda.com/rjanisis/p...B25-033_v1.PDF (Link works, but is wrong)
http://techinfo.honda.com/rjanisis/p...nu/B25-033.PDF
TSB 25-034 - K73 Telematics Control Module Software Updates #1
http://www.urvi.net/forumfiles/SB/B25-034.PDF
http://techinfo.honda.com/rjanisis/p...B25-034-v1.PDF (Link works, but is wrong)
http://techinfo.honda.com/rjanisis/p...nu/B25-034.PDF
TSB 25-038 - Product Update: 2024 ZDX Rear Electric Drive Module (eAxle) Replacement
Applies To: 2024 ZDX - A-Spec, Type S - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B25-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-038.PDF
TSB 25-044 - 2024 ZDX Vehicle-Wide Programming #1
Replaces Job Aid: Vehicle Wide Programming, date June 14th 2025
http://www.urvi.net/forumfiles/SB/B25-044.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-044.PDF
TSB 26-039 - "Service Leveling System" Warning Message with DTC C1194 Air Reservoir Pressure Below Threshold
Applies To: 2024 ZDX - Type S - ALL
http://www.urvi.net/forumfiles/SB/B26-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B26-039.PDF
TSB 26-007 - Safety Recall: 2024 ZDX Instrument Cluster Center Display Software Update
Applies To: 2024 ZDX - ALL - Check iN VIN Status Inquiry for eligibility
http://www.urvi.net/forumfiles/SB/B26-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B26-007.PDF
Old Mar 1, 2026 | 05:35 PM
EE4Life's Avatar
Forum Contributor
Added new TSB 26-007 - Safety Recall: 2024 ZDX Instrument Cluster Center Display Software Update.
AGENTCOZ
ZDX
Mar 2, 2026 11:47 AM
kevin barbee
ZDX
Mar 31, 2022 12:05 AM
