Short Ram Cold air Intake system
Old 03-29-2019, 11:04 AM
3rd Gear
Justin Thomas's Avatar
Anyone know of a canadian site that sells short ram cold air intake for 2003 Acura 1.7EL / 2003 Honda Civic
ebay has some, but also exploring other options, Im not looking for anything special, i know i can spend 300 bucks on a K&N one, but in looking for something for under 100 dollars shipped. I am from Southern Alberta.
Old 03-29-2019, 11:17 AM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
No such a thing, you can either have a cold air intake (which came on your car from the factory) or a warm air short ram intake. You cannot have both.
Old 03-29-2019, 12:24 PM
3rd Gear
so something like here is not technically a cold air intake but rather warm air? even though they call it a cold air intake?
https://www.knfilters.com/cold-air-intakes/acura/el
this is what i have connected to my air filter box right now
https://i.ebayimg.com/thumbs/images/...sGr/s-l225.jpg
I want to remove that, the air filter, and then run a cold air intake right off the throttle body.
just like they show here
https://www.civicforumz.com/civic-di...05-civic-8576/
so you would suggest i just leave the cold air intake in place as typically it will give me more power, correct?
Old 03-29-2019, 12:56 PM
Latent car nut
horseshoez's Avatar
K&N is playing fast and loose with terms. By definition, a short ram is way too short to be anything but a warm air intake.
As for power increases, by changing the intake path you change the resonance in the intake plumbing. By changing the resonance you may well add a few extra ponies up near redline at wide open throttle, however, that comes with a tradeoff in that mid-range resonance is virtually always reduced which will in turn reduce our mid-range torque. So, where do you want the best power?
speedemon90
38
04-28-2009 11:52 AM
QuEeNz03 3.2TL
20
03-15-2009 12:04 PM
apar83
09-17-2007 04:02 PM
EuroR_SG
37
05-19-2006 09:19 PM
03cl1216
05-28-2005 04:16 PM
Quick Reply: Short Ram Cold air Intake system
