Zaino + NXT?
Zaino + NXT?
This may be asinine, but here goes.
I have already clay-barred and applied two coats of Zaino Z2 to my TSX. Now would it be possible to add a layer of NXT (or any other type of WAX) on top of the Z2? Would it be able to "bond" to the Zaino'd surface?
Winter will be over soon (at least here in the South), and I was thinking of adding a couple of more coats of Z2 and then adding a wax. I was thinking that the NXT would help reduce some of my "barely visible" swirl marks.
Any words of wisdom would be greatly appreciated.
Not sure if the NXT will help with your swirl marks, but it will give you that "wet" look that is a bit lacking with Zaino.
Originally Posted by joerockt
Absolutely. I use Meg's Gold Class probably every other month in beween my 6 month Zaino detailing.
Ok, so dont use NXT But you can use any carnauba wax no problem.
