Winter Car Care Tips - Salt Removal
Former Sponsor
Winter Car Care Tips - Salt Removal Wash
Helpful Winter Tips
Make sure the car is completely dry
This BMW 435 X Drive receives a salt removal wash and protect.
Salt Removal - Wash and Protect
Our special pre-soak was designed to chemically remove the majority of the salt and road grime off the paint, with our touch less approach we are preserving the condition of the paint.
After shot
Interior Mats - Salt Removal - just as important make sure your interior is free and clear of salt as it will cause long term damage to your interior bits and pieces.
Before
After
Helpful Winter Tips
- Keeping your vehicle as clean as possible during the winter will go a long way to cut down the damage done by salt and sand.
- Take your vehicle to the car wash as often as possible. If you can get to your undercarriage as well that would be a plus.
- Make sure to protect your car with your favorite wax or sealant.
- Carefully dry the edges of the doors inside and out, including the undersides of door handles, all hinges, plus the hood and trunk edges. This helps keep them from freezing shut.
- Use a good quality spray protectant on all exterior rubber or vinyl surfaces. It may be best to spray they applicator you are using instead of spraying the product directly onto the surface. This will avoid any overspray onto the paint.
After shot
Before
After
musty hustla (02-21-2015)
Helpful Winter Tips
After shot
Before
After
Helpful Winter Tips
After shot
Before
After
what do you use to remove salt stains from the mats / carpet
Former Sponsor
On the Porsche mats for the Cayenne Turbo we used
1Z einszett Plastic Deep Cleaner
Uber Leather and Carpet Brush
Metro Vac
Uber Interior MF Towel
Vac ---> Spritz 1Z einszett on the mats --> use brush to agitate the salt ---> use the microfiber towel to pull the salt off --> vac ---> repeat if necessary
If you have a steamer it will do a great job as well.
Phil
Metro Vac
Phil
Plain old water has about the best affinity for getting rid of salt stains on carpets or mats.
Water is a polar molecule and most salts that would be staining your carpet are either sodium chloride, magnesium chloride or a combo of some sort.
Nothing will dissolve those faster than water. The temp of the water is relatively insignificant too. Hot water will only dissolve a few grams per 100 mL more than cold water.
I use water for the salt, 303 Carpet/Upholstery cleaner for the dirt. Remove with an extractor. I picked up a Bissell Little Green for that and it does a decent enough job.
Former Sponsor
take a look at post #5 the presoak contains two products layered followed by a wash.
Winter Washing at Detailer's Domain - Professional Detailer's Studio - Detailing Bliss powered by Detailer's Domain
tman570
06-11-2019 07:56 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
merc009
10-03-2015 12:59 AM
