Is WD-40 safe to remove tape residue on car?
Most likely depends on the surface you're using it on. I had this nasty sticker on my car window, WD40 and a razor blade was miracle removing this sun dried up sticker.
goo b gone works great
the overexplainer
wd should work on painted surfaces, as others have mentioned along with some kind of citrus based cleaner. I'm sure Simple Green wouldnt hurt either.
Received 3,824 Likes
Not to but I have Gorilla Glue on my bumper what would remove that without harming paint?
Just asking because I'm not sure if above cleaners would remove Gorilla Glue.
I'd be surprised if anything removed that without damaging the paint. That stuff is tough, maybe someone else can give you a tip.
Undying Dreams (04-09-2013)
Received 1,080 Likes
How do I clean up Gorilla Glue? [-]
Wipe off excess glue immediately with a dry cloth or standard paint thinner. Do not drag glue over material, instead make small swipes to remove wet adhesive. Make sure you avoid skin contact. Cured glue can be removed with a chisel, scraper or sandpaper.
nanos
11-12-2015 08:41 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
