Wax on
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
I have a 07 tl/s, live in the southeast with "hard water". I recently waxed my car but...water spots remain. Any suggestions would be helpful. I did find a great glass cleaner- Invisible Glass by Stoner. Works Great, best I have found. I have the carbonized window tint(Tint World, Fla)-dealer said it was safe to use.
Thanks for the assist-----Merry Christmas to all!! R
Do you dry your car after you wash it normally? I'm in the southeast and I don't have this problem. Where are the water spots? Do you park around sprinkler heads? Does your sprinkler use Well water?
You're better off posting in the Wash & Wax forum. https://acurazine.com/forums/forumdisplay.php?f=23
I live in Savannah, yes I dry after everywash...lawnblower and clean dry towel. The spots are mostly on flat surfaces, might be from rain. I don't park near any sprinklers. I have city water and if any does dry on any car it leaves white spots. Is there a good wax to work the spots out?
Sorry for the mis-post...
BTW-coming to your beach for XMAS! Thanks again, R
Former Sponsor
Waxes will tend to seal in your water spots. You need to remove the spots with a polish or chemical cleaner. Just wait and take care of it with your quarterly detail (which im certain you do right?)
As for your particular water condition, consider using a quick detailer when drying. Simply spritz the QD on the wet surface and dry away with a waffle weave. Also, using an auto wash with a fairly balanced ph helps.
Do not wax your water spots, it will seal and build a coat top of unwanted spots. Your best bet is clay bar, paint cleaner, glaze, then sealant then possibly wax if needed. (meguiar's, and wolfgang for the sealant by the way)
mugen_kid
11-13-2015 10:38 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SinCityTLX
55
10-11-2015 01:20 AM
