Volk CE28n covered in brake dust and tar
Hey my volks ce28n in bronze are starting to accumulate alot of brake dust / tar, what cleaner should i be using i have tried the p21s wheel gel but that didn't seem to take off the brake dust/ tar. I have read that wd 40 is good for taking off brake dust and tar, will this be safe for my wheels?
If your having trouble getting it off it means your neglecting your wheels, once you do get it off you should change your washing practices. There is going to be a point when the brake dust eats through the clear and you "don't" get it off.
Brake dust can become acidic once exposed to moisture and will eat the clear on your wheels. Also the cleaners your going to be using are harsh and eventually not great for your wheels. Think of it this way ... would you use the wheel cleaners on your hood?
For the tar use a rag wetted with mineral spirits to wet the tar down .. let it linger on the tar .. don't start rubbing right away cuz a lot of tar contains sand and will mar. The tar will start to run brown and thats the time to use the wetted rag to rub it away.
should i try this after i try megs wheel brightener or would this method be safer?
The wash water will do just fine.
Bend down and use a dedicated wash mitt.
I feel like I am having to really scrub it off.
It's taking me 7-8 minutes per wheel and I feel like I am doing more work than is necessary.
Maybe the issue with my routine is that I never applied a wheel sealant (like Poorboys).
Clean them up and go get a bottle od NuFinish liquid and put on a layer ... you will spend less time doing that once than you will cleaning the way you do now and a lot better for the wheels.
I have seen a lot of dulled wheels from people thinking they needed to use a wheel cleaner every wash.
