TurtleWax Wash & Wax, REJEX
Just wanted to hear what other people thought of REJEX wax and TurtleWax "Wash N Wax".
I use the Rejex wax, it lasts a really long time and I say it is better than that zanio garbage. They say it lasts 6 months, it looks great and works great!
I also wash my car with the wash n wax, it is easy and looks like the car was just waxed, this is the best stuff I have found to use on a black car.
Here is some info on the Rejex:
RejeX is a thin-film polymer coating designed to provide a high-release surface. This very thin film – less than a micron thick – prevents stains and adhesion of common contaminants such as exhaust, bugs, oil, tree sap, bird droppings, road grime, brake dust, etc. It also makes graffiti easy to remove and can be applied to windshields to repel rain. It’s easy to apply and produces a deep, lustrous shine that outlasts the most popular waxes by months.
RejeX contains none of the free silicone oils found in some other products that are known to contaminate paint and cause problems when repainting.
APPLICATION RejeX should be applied to a cool (less than 85° F) dry surface out of direct sunlight. If the surface is too hot, the coating will cure before it has properly bonded to the surface, and it won’t perform up to its potential. RejeX is wiped on, allowed to dry to a haze for approximately 20 minutes, wiped off, then allowed to cure for 12 hours. Curing is required to allow the monomers (polymer building blocks) that make up RejeX to attach to the surface being treated and to polymerize (crosslink) into a crystal-clear, impervious film. It is very important to allow RejeX to cure for 12 hours after the haze has been wiped off. If the coating is exposed to contamination such as oil, fuel, soot, water, cleaners, etc. before it has cured, the contaminants may interfere with the film, preventing the RejeX from achieving it's maximum performance and durability.
PROTECTS AND BEAUTIFIES PAINTED METAL, GLASS, ACRYLIC, GEL COAT, FIBERGLASS, GLOSSY PLASTIC & POLISHED METAL SURFACES
RejeX is not meant to be used on porous surfaces, highly oxidized painted surfaces, or to fill fine scratches. RejeX can be applied in multiple coats, allowing 8 hours curing time between coats for deeper color and greater depth of gloss. RejeX has a higher refractive index than waxes, so it produces richer, deeper looking colors and a lustrous long-lasting finish. RejeX can be used over existing wax; however, the duration of protection will be reduced as the softer underlying wax degrades comparatively quickly. There is no reason to wax over RejeX. As we’ve already said, RejeX leaves a shinier, longer-lasting finish than wax… and the wax can't adhere well to RejeX!
emailnatec
29
09-28-2018 04:27 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
