Tear in my leather, doh!
7th Gear
Help! I have a small tear in the leather in my back seat of my 06 TSX. How can I fix it? It's not a gash more like a cut or something. Like a slice but with a flap over top of it. Does anyone know of any good leather repair kits? Again, pretty smalll, like less the two inches long. It'e ebony leather. Thanks!
The Old Grey Whistle Test
Repairing Cuts and Tears:
A cut through the leather must be repaired with a patch on the underside.
Methodology
•Slice through with a one-sided razor blade to gain access to the underside. The leather patch must be larger than the cut, work the patch into the hole so it can be glued to the underside of the seat leather, suede sides together.
•Use suitable leather adhesive that can be sanded (Rightlook leather adhesive, Rightlook.com) do not use contact cement because it adheres instantly when the two surfaces touch, which would prevent an inside patch from being worked into position.
•Apply the glue through the hole so that both the seat leather and patch are coated
•Work the patch into place, then press the two pieces together and hold them there until the glue sets up. After the glue has cured fill the repaired cut with flexible filler
Methodology
7th Gear
Originally Posted by VQPower37
if its juss a flap over another flap, y dont u juss try glueing down so the tear doesnt show and glue will hold it in place
Originally Posted by RachaelMC
I think I will try that. Thanks!
A cut through the leather must be repaired with a patch on the underside to act as reinforcement (it has torn at its weakest point)
Methodology
Methodology
emailnatec
29
09-28-2018 04:27 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
