Sweetjazz's 2007 NBP TL-S (Spring/Summer Detail)
Old 07-06-2008, 01:19 PM
2016 E350 Sport
SweetJazz's Avatar
I finally got around to my spring/summer detail a week ago. I used a completely different product/machine combination this time and I am pretty happy with the results.
                Just a few notes:
                          Photography is not my strong suit but I tried manipulating some of the manual settings on my parents 6 MP Kodak Easyshare Z650. I'm looking to get a Canon Digital Rebel XSi by the end of the year.
                          I got up early and took some sunrise pics. Enjoy.
                          Old 07-06-2008, 03:51 PM
                          conan777's Avatar
                          Looks Awesome man! Now that is how NBP is supposed to LOOK!
                          I use many of the same products and agree with you 100%. Menz polishes are top Notch but def dust alot especially if you run it over some tape. I'll periodically add a drop of OP to cut the dusting down but you only need very little. A spray of H2O, quick detailer or pad lubricant works also.
                          Did the XMT360 eliminate any of the swirls on the clear bra or simply fill them in? I have used SIP, PG and 106ff on clear bra's, and all worked pretty good and did not harm the clear bra. You do have to be very careful around the edges though if the shop that installed the clear bra did not roll the film around the edge. Some installers simply cut the film near the edge.... in that case the buffer can "roll" the edge of the bra and it will look like it is "Burned". Just a heads up!
                          Old 07-06-2008, 06:56 PM
                          2016 E350 Sport
                          SweetJazz's Avatar
                          Thanks for the props conan777,
                          I did not have much success with the water or QD. I'll try the OP next time. The XMT360 most likely filled in some and corrected some. I have the 3M version and I did not want to mess it up with something aggressive. I spent about an hour taping off all of the edges. I purchased some 1/8" and 1/4" painters tape that worked out perfectly. Cleaning clear bra edges is no fun.
                          Old 07-29-2008, 04:01 AM
                          eluzion's Avatar
                          Would you say the Danase Glaze is worth it? I'm about to do a wash > clay > optimum polish > four star sealant. Not sure if I should throw the Danase Glaze after the Optimum Polish. I really love that wet look.
                          Old 07-29-2008, 07:31 AM
                          thunderbt3's Avatar
                          Four star for the protection, Danase Wet Glaze for the looks. I apply FSUPP first and then layer DWG on top after 24hrs. You can use DWG alone but UPP has much better durability.
                          https://acurazine.com/forums/wash-wax-23/dwg-upp-393773/
                          Old 07-29-2008, 11:42 AM
                          2016 E350 Sport
                          SweetJazz's Avatar
                          Danase Glaze is definitely worth it for dark colored vehicles. I am not sure how it looks on white or silver. I think it is best to apply to one panel/fender/door and then wipe off. I found that if you let it sit too long it is harder to remove. The results are fantastic. It is also great that this product can be used over or under a LSP.
                          Old 07-29-2008, 01:39 PM
                          bo0sty's Avatar
                          do you hand apply or do you work the glaze in with an orbital
                          Old 07-29-2008, 07:47 PM
                          eluzion's Avatar
                          ^ What he said. I'd imagine using an orbital buffer with the softest polishing pad would be the best route. Also, how long do you let it sit before wiping off?
                          Old 07-29-2008, 09:43 PM
                          Fulani has a TL's Avatar
                          SweetJazz, I always enjoy looking at your car, makes me want to detail mine (if only a day consisted of 30 hours) haha.
                          Great jobb
                          Old 07-29-2008, 10:16 PM
                          Former Sponsor
                          exceldetail's Avatar
                          Speaking of Menzerna, Exceldetail.com will soon have some news about a new polish coming out (not from Menzerna). Rest assured, its another winner.......
                          SJ, very very nice looking foh sho!
                          Old 07-29-2008, 10:29 PM
                          Deep Gloss's Avatar
                          Looks VERY nice!!
                          Scholl???
                          Old 07-29-2008, 10:42 PM
                          2016 E350 Sport
                          SweetJazz's Avatar
                          You can use both. Just use a slow setting for the machine.
                          Old 07-29-2008, 10:44 PM
                          2016 E350 Sport
                          SweetJazz's Avatar
                          Great jobb
                          Thanks Fulani!
                          Yeah I know what you mean. I take too long on my details to turn it into a business but then again I would probably get burned out due to the time pressure.
                          Old 07-29-2008, 10:45 PM
                          2016 E350 Sport
                          SweetJazz's Avatar
                          Uhhhhh.............any hints?????
                          Old 07-30-2008, 10:46 AM
                          Former Sponsor
                          No hints, no ifs, no ands, no butts.................
                          Coming soon. (I actually have the approved sample, and naturally just detailed my vehicles before I received it)
                          May have to do another sample give-away!!
                          Old 07-30-2008, 09:40 PM
                          Deep Gloss's Avatar
                          My bet is scholl...lol
                          I just ordered the full package from them and cant wait to try it.. it arrives tomorow
                          Old 07-31-2008, 12:30 AM
                          Kang Ho
                          SupaRookie's Avatar
                          waiting for sample run. hopefully I can get in.
                          Old 07-31-2008, 02:09 AM
                          bo0sty's Avatar
                          i may need to try adding a glaze into my line up
                          car looks great
                          Old 08-21-2008, 04:09 PM
                          eluzion's Avatar
                          Out of curiosity, what product do you use for your tires? I don't like the complete wet/shiny look but just a clean appearance like yours. Maybe you just have really clean tires...
                          Old 08-21-2008, 06:49 PM
                          bo0sty's Avatar
                          i've seen OTC tire dressings that give a matte finish
                          Old 08-21-2008, 07:05 PM
                          eluzion's Avatar
                          Any recommendations on which kind I should go with? I remember some of them leaving a real nasty brown color after their shine wears off. I'm hoping I can avoid that. I was thinking about picking up the Meguires tire shine (it's a spray on kind).
                          Old 08-21-2008, 11:23 PM
                          bo0sty's Avatar
                          sounds like that would give you that oily shine finish. i dont really know as i dont dress my tires
                          just try to find one that has good durabillity.
                          Old 08-21-2008, 11:33 PM
                          2016 E350 Sport
                          SweetJazz's Avatar
                          I am currently using Meguiars Hot Shine Tire Gel. I do not like a tire to look really unnatural with a wet shiny look. I prefer a satin look to the tire. Also note that the tire itself will determine the look you get. The Yokohama tires I have are super difficult for applying tire dressing. The sidewall compound just does not accept tire dressin very well. Now the tires on my Civic look great with just an application of 303 Aerospace Protectant.
                          Old 08-22-2008, 12:06 AM
                          eluzion's Avatar
                          Ah, I might have to give that 303 a try since I have some coming in. If not, I think I'll pick up some Meguiars Hot Shine Tire Gel!
                          MrHeeltoe
                          20
                          02-23-2023 01:54 PM
                          08KBP_VA
                          10-22-2019 01:55 PM
                          MetalGearTypeS
                          08-29-2016 08:28 PM
                          MrHeeltoe
                          09-29-2015 10:43 PM
                          MrHeeltoe
                          09-28-2015 05:43 PM
                          Quick Reply: Sweetjazz's 2007 NBP TL-S (Spring/Summer Detail)
