Removing Wax
Removing Wax
If you do a full wax every couple of months or so is it necessary to remove any previous wax put on? Since the waxes wear off after a few months, I was planning on just waxing again and not using a product to remove previous wax jobs.
some people recommend paint cleaners etc to stip all wax on car before doing a wax job. seems like a lot of work, and can't imagine it makes a huge difference. Also some recommend using a polish before waxing but again, not something i plan on doing.
Originally Posted by ctsport
I recomend using Dawn dishwash to strip the old wax before applying the new. Its simple and easy and you have to wash/detail the car before waxing anyways.
DO NOT USE DAWN ON YOUR CAR!!!!!!!!! All of the detailing forums I belong to say that is the dumbest thing you can do. I wash my car then I use meguiars paint cleaner and then nxt gen tech wax. Or I use meguiars paint cleaner , polish, and deep crystal wax.
The way I understand it is, you only do it the first time to get the car as clean as possible. Once you get the first coat of wax on, then you don't want to use Dawn anymore, but a standard car wash soap.
Is that right?
If you wax with carnauba ever few months is it necessary to use a paint cleaner each time you wax? If you don't will this make the new wax less effective?
By the way, no possibility of me putting dishsoap on my tsx nighthawk black.
Most consumer-type waxes (like Meguiars Cleaner-Wax) actually have enough chemical and abrasive cleaners in them that they will remove the previous layers.
Reading between the lines of your post, you're probably waxing again with the same type you used before ... so no removal necessary.
Originally Posted by 04EuroAccordTsx
i have white wax residue stuff left on the black mudguards, i even tried an eraser, its still there!
I'd suggest a search on www.autopia.org .
most say that after a few months virtually all of a wax job is gone, so it doesn't make much sense to try to remove wax after several months if it is not there anymore. If you want to do a perfect job then i guess a paint cleaner to remove the wax can be used. otherwise a whole lot easier to just use a wax, especially a liquid wax like pinnacle's new liquid wax.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
dainmezron
10-16-2015 06:56 PM
SinCityTLX
55
10-11-2015 01:20 AM
