removing heavy oxidation on headlight
Old Jan 25, 2008 | 01:45 PM
dnd2984's Avatar
What the best way to clean this off. It on our 1999 suburban. Can it be sanded down then be protected by clearcoat?
Old Jan 25, 2008 | 07:09 PM
Hawhyen51's Avatar
This article should provide some answers. I know there are some threads about this . . . here ya go . . .
https://acurazine.com/forums/showthread.php?t=171457
https://acurazine.com/forums/wash-wax-23/headlights-question-373467/
https://acurazine.com/forums/wash-wax-23/haze-over-headlights-how-do-i-remove-338154/
https://acurazine.com/forums/wash-wax-23/headlights-cleaning-307697/
Originally Posted by TOGWT
Removing Oxidation or scratches from Vehicle headlights, Fog or Brake lights (polycarbonate) In the late 1980’s, vehicle manufacturers changed the lighting lens system materials used for head lights from glass to Lexan (plastic ) to protect expensive lamps (headlight assemblies range from 500-$700+) from flying stones and road debris. The lens starts to exhibit an opaque appearance and then a yellow hue on the outside of the lenses and can severely restrict the amount of light reaching the road. Original equipment material (OEM) suppliers started to add a UVR protection to the surface of the lens in an attempt to reduce this condition and prolong the usable life of the lens.
The lens has a silicone-based coating applied to its outer surface, some manufacturers apply two different types of coatings to the outer surface of the lens, these coatings are mainly for UVR protection, but are also for impact and abrasion resistance, once the coating (s) fail the lens surface will occlude (clouding or yellowing)
While most of the cloudiness is on the surface, severely discoloured lens cannot be brought back to optical clarity. If you live in a southern state, this discoloration can become noticeable in as little as two-years. You could also use a metal polish (Reckitt and Coleman’s Brasso®)
Novus 1 - gently cleans all plastics without scratching, leaves a lustrous shine that resists fogging, repels dust, and eliminates static.
Novus 2 - removes fine scratches, haziness, and abrasions from most plastics (exceptional for removing scratches from Plexiglas). Use repeatedly and restore faded and discoloured plastics.
Novus 3 -removes heavy scratches and abrasions from most acrylic surfaces. Contains abrasives, not for use on eyeglasses, polycarbonate, or coated plastics, final finishing also requires the use of Novus 2 http://www.modernplastics.com.
Application Methodology:
•Use a solvent type cleaner (Klasse or Zaino All-In-One) if this does not remove the oxidation use a plastic polish
•Meguiar’s Plastic Polish (PlastX ) - http://www.autopia-carcare.com/meg-g-12310.html) that contains a microscopic diminishing abrasive, which requires a little pressure when applying it to enable these abrasives to remove the discoloured plastic and expose new plastic.
Call the site sponsor Exceldetail (Patrick) he will advise you on products, There are some How-To article's on his site they may help you with your detailing or ask your questions here we are always willing to help * * *
Old Jan 28, 2008 | 11:36 PM
dnd2984's Avatar
Old Jan 29, 2008 | 07:31 AM
exceldetail's Avatar
Former Sponsor
Im about to re-do mine as well. Although the initial UV coating has "expired" I think I can mae a vast difference with simply polishing. Im going to go with a 3" drill kit I have with some compounds and polishes and see what happens......
(Tape off surrounding painted areas also)
Old Jan 29, 2008 | 08:53 AM
dnd2984's Avatar
pics.... I am doing this on our 99 Suburban couple years ago I bought the $20 kit from autozone and that was just a waste of money
Old Jan 29, 2008 | 09:02 AM
vinnier6's Avatar
i have always in the past, waxed the tail lights and headlights as part of my routine, is there a benifit in doing this, will it prevent the oxidization or not...i have never had a car or bike with the oxidized lights....
Old Jan 29, 2008 | 07:04 PM
01tl4tl's Avatar
fsttyms1 recently did his with the buffer and some polishing compounds- high speed sandpaper! look better than new now. Other use a powerball and the parts store kit.
Use synthetic car wax on the plastic covers once clean- carnuba wont take the heat of HID headlights or wheels
HairyMonkey019
Apr 22, 2016 10:50 PM
pistacio
Sep 26, 2015 09:45 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
