Recommend a polish for dark paint colors!
Going to attempt to detail my abyss blue pearl TL for the first time. Nothing extreme, just light swirls (only visible in direct sunlight) so I'll probably only use polish and not a cutting compound. I have no experience with soft paint or dark colors so I need recommendations. I'm leaning towards either Sonax Perfect Finish or Meg M205. I have also heard good things about Sonax Paint Cleaner on Honda paint, but I'm worried it won't be enough to remove swirls. If it matters I will be using a DA most likely with an orange foam pad.
If you have any results pictures of a product you used, please post it! |
Megs 105/205 is a good combo. I've heard their ultimate polish is Megs 205 adjusted so it doesn't dry out so fast and gives you more work time.
Originally Posted by projektvertx
(Post 16136815)
Originally Posted by ACURAte_tiTLe
(Post 16135443)
The paint was near perfect with slight imperfections. I used a Lake Country CCS blue pad (final finishing) on my Flex XC 3401 VRG dual action polisher and Meguiar's M205. I'd sooner work slow on my original paint (solid and not clear coated). Its not like I am running a business and need to cut fast. I took paint thickness measurements before and after, nothing removed worth mentioning. |
