Product alerts, Klima Cleaner, Silber Spray for wheels
Former Sponsor
Silver Spray Wheel Paint (Silber Spray)
Here we are again... Silver Spray paint is back in stock and will be shipping out to those of you have ordered the product. Unfortunately, all inventory is spoken for. If you didn't preorder, the next 'wave' of inventory arrives the first week of October. The October arrival will be our largest shipment yet so we will not have backorders for a while - we hope. Customers are very happy with the results as we see sales continue to grow and grow.
Shipping:
Like all aerosol products, Silber Spray can only be shipped via Ground. Air shipment is forbidden.
Klima Cleaner
We continue to see sales of Klima Cleaner climb. More and more customers are finding out that they don't have to deal with musty odors inside their car and that it's not enough to clean just the outside of the car but every aspect of the interior as well.
Summer is nearly over and many people think that musty odors due to humidity is over. But this isn't the case. The A/C is often used during the winter in conjunction with the heater to remove moisture/fog from inside the car when it's raining or snowing outside. The mositure that is pulled from the air continues to collect inside the evaporator core where mold, fungus, dust and other debris collect.
If you ever have a chance to open a dialogue with a customer, Klima Cleaner is a unique item to bring up to your customer.
During Klima
After Klima
Usage and Tips:
1. One can can treat two cars or one large vehicle such as an SUV.
2. Encourage customers to treat all their vehicles at least twice a year: once in the summer and once in the winter. Summer is primarily known for being the time to treat A/Cs but the winter is also a time when drivers use their A/C to de-humidify their cars.
3. Dealerships charge up to $150 for this service and they use the SAME product!
4. Klima Cleaner is excellent for customers with severe allergies. In addition, Klima is water-based and does not contain any skin irritants.
Shipping:
Like all aerosol products, Klima Cleaner can only be shipped via Ground. Air shipment is forbidden.
Shipping:
Klima Cleaner
- "Do you notice musty odors?"
- "Have you thought about treating you're A/C today?"
- "Have you considered treating you're A/C today?"
- "We have a great new product that treats odors and improves the health inside your vehicle"
- "How about treating the inside of your vehicle"
During Klima
After Klima
Usage and Tips:
Shipping:
Former Sponsor
This oughta cover it!
From einszett:
Spray Paint Procedure Silver Spray (970330) features:•Acrylic lacquer-based paint.
FYI: Compatibility - Lacquer paints can have either an enamel-based or other lacquer-based paint applied on top. However, you cannot spray a lacquer on top of an enamel-based paint.•Contains high solids. Extremely durable with longevity extending as muchas 10 years without discoloring and is stone-chip resistant.•An exact match for OEM European wheels found on BMW, Audi, Mercedes, VW, Porsche, Ferrari, Lamborghini, etc. DOES NOT match specialty wheels such as Mercedes AMG wheels which has a more “brilliant” silver finish. DOES NOT match BBS wheels. They have their own proprietary silver.•Also used as a trim paint.•NOT FOR USE as an engine or brake caliper paint. Both these surfaces sustain high temperatures. Silver Spray is not formulated for high temperatures.
Application On Painted Surface
1. Always suggest user test paint on back of wheel or on test patch FIRST.
2. If painting directly on painted surface, user should clean surface thoroughlywith a detergent such as dishwashing soap. Rinse thoroughly after washingso the surface is free of any soap residue. Dry completely with a lint freecloth.
3. Spray light even coats. Heavier application will cause orange peel and drips.
Application On Putty Filler Or Bare Metal
If a user is repairing a curbed wheel, they will need to use putty to repair the damaged area. Since putty and bare metal are not an ideal surface to apply Silver Spray paint, thesurface must be primed with a self etching primer such as einszett’s Primer “Haft-Grund” Self-Etching Primer (970310).
1. Prior to painting, user must spray Primer “Haft-Grund” (970310) on filler andbare metal to provide a base for Silver Spray Paint
2. User should NEVER spray Primer on painted surface which will soften thepaint due to the ‘etching’ properties of the primer.
3. After spraying Primer on surface, user should sand surface according toproduct directions on Primer can.
4. After sanding, user may proceed with Silver Spray Paint.Applying Clear Coat Since einszsett does not currently have a clear coat, the following brands are recommended (Note: Use of any other brand will cause discoloration, poor adhesion,and or softening of the paint due to incompatibility).•Wurth clear coat. Any Wurth brand clear coat is compabile with einszett SilverSpray.
Note: Wurth Clear Coat may become unavailable as some dealers are stating that they are unable to obtain this product.•Dupli-Color “High Quality Wheel Paint” More readily available than Wurth, this particular series of Dupli-Color paints has been confirmed by several customers that the product is compatible with einszett Silver Spray. Please note that this has not been confirmed by einszett and so it should be clarified to dealers and users that they should always test on the back of wheel first or on a test patch. Also, compatibility is not guaranteed.
From einszett:
The Klima Cleaner, you just run the hose down the upper vent and spray it all in? I take it your A/C must be off. Is that it?? Do you have to wait a certain time period before using the A/C after treatment?
Former Sponsor
Bahda Bing...........
Klima-Cleaner is an effective means for removing odors from the air conditioning unit by treating the source of the odor. While other products eliminate the odor by neutralizing or masking the source of the odor, they don't clean the evaporator core surface - the heart of the air conditioner system where water condensation accumulates and where the odor originates. Klima-Cleaner's active foam works by 'scrubbing' the evaporator core reducing the opportunity for odors to reappear. Simply insert the included spray hose into the center air vents in your vehicle's interior and spray. Allow to work for 30 minutes. Creates a fresh smelling environment that lasts for months. To maintain results, we suggest you treat the system at least twice a year - in the spring and fall.
I tried Klima clean, and it stinks horribly! weeks later! think it's the ammonia in it?? I'm going back to the A/C pro odor eliminator ($12 at my autozone, contains 2-Butoxyethanol)- It worked very well, no stink (except for first day).
The Old Grey Whistle Test
TOGWT® Autopia Detailing Wiki - “Air Conditioner Cleaning” - http://www.autopia.org/forum/guide-d...ml#post1447731
These informational resources contain everything you’ll ever want to know about automotive detailing and are an invaluable addition to your detailing knowledge base.
rockyboy
08-04-2024 10:35 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
