Preventing hard water marks when washing car
I caught the mod flu
I know how to get rid of the water marks, that's not the question.
I did a search and found a tool called, waterstick. Wondering if anyone here has used it and if so, how does it work?
Of course I could go out and buy an expensive water filtration system but I'm looking for a cheaper solution untill I can purchase a real solution.
This the one?
Water Stick
4.5 GPM CONTINUOUS FLOW WITH NORMAL WATER PRESSURE ... fill a 5 gal. pail in 1 minute and see if thats enough flow for you ..
Might work ..
Water Stick
Might work ..
Originally Posted by Jesstzn
This the one?
Water Stick
Might work ..
Water Stick
Might work ..
Originally Posted by probmxstyle
how are you getting water spots??...i can wash and dry my car without getting them, maybe you need a little technique help....important, never let your car dry on its own...even after i have washed a section, i keep spraying it down until i have completed the whole car, then i hit the whole car again with the hose, then roll it into the garage for the drying process...be quick about the drying process at first, to get most of the water off, then you can come back and do a final wipe down...as long as you not drying your car off in the sun, you shouldnt have water spots....
When I wash my car I first rinse the whole car down, after each section like the hood, roof, door, I then rinse that specific section to get the dirt off but I re spray the entire vehicle down as well to keep it wet. So wash a section, rinse it and rinse the other sections as well quickly. Then I'll respray the entire vehicle right before I'm going to dry it.
I used the advice given buy you guys over since I started this thread. I'm stlill having water spot issues. My water must be very hard!
No matter what I do, I still have water spot!!!
The Detailer
You can always purchase a CRSpotless and you'll never really have the issue again. Of course, if you want to go the cheap route, you'll have to resort to some sort of inline filter or even cheaper, ONR!
The Old Grey Whistle Test
Patrick's suggestion is a very good intrim solution before going in for a filtration system
See article Water Filtration - - http://detailingwiki.com/index.php5?...er_Filtrationr Filtration -
I think I might go this route first. Any suggestions on removing the water spots i have now? Next week Id like to polish and wax but need to remove the spots first. I got so frustrated over the summer I just gave up!!!
If you resort to NRWS, you can wash and dry one panel at a time......available in 8, 32 and 128 oz sizes, only at Exceldetail.com
Not being able to pre-rinse the larger stuff off like you normally would?
It just accured to me that when it rains the rain water loosens the minerals found in the water from the previous wash causing more water spots.
The Detailer
MY concern with a NRWS like ONR is I live in a 4 seasons area. I come out most morning and fin debree of all kinds on my car. How do you suggest using ONR in my situation and not being able to use my water due to hardness.
I actually just thought of another idea, but wasn't sure if it would work and hoped one of you may have tried it. I was in my garden shed the other day and saw one of my hose end sprayers sitting on the shelf and thought I could use this with a liquid softner solution on tough days when I was driving on salted snow roads.
What do you guys think?
The Detailer
AFAIK, I don't believe the car wash soaps have much to do with leaving water spots on your vehicle. It's the minerals in your tap water that cause the water spots.
