Need some guidance for NPB
Hey guys - newbie here so any help is greatly appreciated.
First time using a Porter Cable on my NPB TSX and not getting the results I want.
My Process:
Optimum Compound II With Hydrotech Blue Pad
Optimum Polish with Hydrotech Tangerine
After I do the Opt Compound II I can see immediate results with removal of a ton of light swirls and scratches. The paint looks much clearer but there still remain some deeper scratches that just wont come out.
Do you guys think I need to get some heavier cutting pads or a different combination to get some better results? What would you suggest?
It doesn't help that I see all the excellent detailing write ups on this forum and expect better results..even for my first time. Thanks in advance!
My Process:
Thanks Excel!
I know I am going down a dangerous road with detailing. My brother just saw my work and he said it looks fine but I can see the scratches in certain angles. I can see how this gets addicting fast.
Former Sponsor
Ok, I deleted my previous reply after researching the latest and greatest Hydro tech, lol. (sorry)
Try the orange with the Compound. It appears the blue is more aggressive then the Orange?
Your order of aggressiveness is as follows, from least to most.
Opt Pol/Orange
Opt Cmpnd/Orange
Opt Pol Blue
Opt Cmpnd/Blue
Once you use Blue and/or the compound, chances are your going to need to follow up with the Polish II and a finer pad, which I hope youhave.
Opt Pol/Orange
Opt Cmpnd/Orange
Opt Pol Blue
Opt Cmpnd/Blue
Opt Pol/Orange
Opt Cmpnd/Orange
Opt Pol Blue
Opt Cmpnd/Blue
Opt Pol/Orange
Opt Cmpnd/Orange
Opt Pol Blue
Opt Cmpnd/Blue
Some deeper scratches still remain though. I am not sure if its my technique or my product/pad selection.
So from a product pad standpoint I have used the most aggressive I have currently. How long does it take to work in optimum compound?
Former Sponsor
Its definitely not the product. I can vouch for the Optimum products. Its hard to get perfect results first time around, this is all new to you! Secondly, its more then likely not the pads either. Its just the fact that you are not familiar with what your doing, the pad and products characteristics are totally unfamiliar. I suggest you go back to the lightest combination you have, and try again, but adjust your technique. Its EXTREMELY important that you familiarize yourself with the products and combinations, pressures applied, speeds used, arm movement etc. I always suggest a minimum of three passes. DONT stop there. As long as you have lubrication, do 4, 5 or even 6 passes. The worst thing you can do is expect professional results the first time out, it just doesnt work that way. You can expect cleaner paint, and more clarity.
Be patient, and try again. Every time you use your PC, you WILL learn something.....
Thanks Excel.
I am going to try it all again today. I did a little more research and I dont think I am letting the polish break down long enough. I am going to do some extra passes and see how it turns out. Thanks again for your help.
Optimun doesn't break down like the megs stuff because of the lubrication properties so you can work it a long time ... You also might be using too much thus not letting the product to work.
I am using 3 nickel sized dots in a triangle for a 5.5 inch pad. Is that too much?
Former Sponsor
peregrine22
ILX Audio, Bluetooth, Electronics & Navigation
01-12-2017 10:32 AM
johnpancakes014
09-27-2015 12:58 PM
