Microfiber Towels
The Old Grey Whistle Test
I would suggest you wash your towels twice before initail use to ensure that there is no lint residue or chemical sizeing remaining in the towels nap.
Washing Directions- Use hot (120oF<) water and add 1-2 ounces of liquid laundry detergent (Woolite) to a standard size (8 gallon) load, for larger loads or heavily soiled laundry, add 3-6 ounces. As a pre-spotter: dilute 1 part concentrates with 3 parts water, apply to stain and launder as usual.
Do not use fabric softener (most contain silicone that the towel will adsorb and it will cause smearing of the paint surface thereby reducing their effectiveness) towel will also treat the fabric softener as if it was dirt by trying to store the tiny particles of the softener in the towel fibres. This will clog up the micro fibres and render the towel ineffective. Add a teaspoon per towel distilled white vinegar in place of a softener, the vinegar doesn't coat the fibres but instead works to eliminate detergent residue. Vinegar (Acetic acid, pH=2) works well in the rinse cycle to make your towels softer. Detergent is an alkaline (pH=12, the opposite of acidic on the pH scale). Air dry or you can dry micro fibre cloths / towels in any dryer on low heat, remove them before they are still damp (cuts down on static charge) Colours may bleed during first washing.
JonM
JonM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
