Little scratch swirls after use of ScratchX on a NBP TL?
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Hey all:
I just took delivery of my brand new NBP 08 TL three days ago. Well, I found a small scratch on the trunk that I thought I could fix easily. It seems I may of caused more problems for myself.![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Anyway, after reading the directions multiple times, I started applying to the specific area. After looking at it in the light though, I can see very small scratch marks, very fine, but I can see them when light reflects off of the applied area.
I am using the foam sponge (I called their 1-800 number) and it seems to not help to no avail. From what I've researched, I'm supposed to rub the ScratchX, none of the product should be wiped off.
Suggestions? Am I SOL? Anything that may fix this?
Former Sponsor
Well you have to wipe it off! Use a small amount with either a foam app or mini microfiber. Apply in the same direction as the scratch, until product disappears or dries. Then wipe away with MF.
Personally, i dont really like the Megs SctatchX? I dont really like recommending its use, especially on NBP. I think what your seeing are halograms from the abrasives breaking down too quickly, or perhaps you didnt use enough and sort of buffed it dry. Ive used it a few times but always had better results with traditional polishes applied with a 4" pad and UDM/PC.
I think I was going to have a heartattack yesterday when I did this, so you'd make my day if you can help!
scratch x isnt really abrasive enough to micro marr your paint, so i would think with a little patience you can buff out the marks you have...i would use a dime size amount on your foam app, and buff in small tight cirlces until the product starts to haze and dissapear, dont keep working it in until its completely gone, but you do need to work it in until it breaks down...buff clean with a clean microfibre, and repeat....
2012 SH-AWD / Advanced
Welcome to the wonderful world of NBP!! I have one, and it's a very tough battle to keep it in top-notch shape (and I get paid to detail cars!).
You will need to learn and perfect your washing and drying technique right away, otherwise you will go crazy! I've had MF towels in the past that while soft, still induce marring in the paint.
The best I've found are the Eurow Shag MF towels (Patrick sells them).
Best of luck.
Best of luck.
Registered Nutsack
If it's only a minor scratch then use this
http://www.quixx-usa.com/products/overview/47/In:en
It was rated #1 in Consumer Reports and it actually works. You rub the "Step 1" stuff in for a minute or 2 then put the Step 2 polish over that and your done.
The stuff kicks ass
The stuff kicks ass
I'm going to get some new foam sponges again and try the ScratchX and see what I can do. If not, I'll buy this stuff.
Best of luck.
Best of luck.
I have never used a udm/pc before, so I have quite a bit of homework before I use that. You think using a udm with ScratchX will take care of this?
Former Sponsor
using a udm/pc couldnt be easier, very user friendly, and near impossible to damage your car....with a pc or udm, you wont even need scratch x...just a normal mild polish and a white pad....you will want to polish out your whole car and seal it after, and it will glow better then new...
Registered Nutsack
Right, a PC/UDM would be ideal down the long road of paint maintenance. I was just suggesting a quick and economical fix. When you start talking about PC's and UDM's you're now talking about spending $100-200, rather than $18, and that's not including the $10 pads and $20 backing plates, etc. Quixx beats ScratchX hands down. Meguiars makes some good stuff but, ScratchX is garbage IMO.
Former Sponsor
InFaMouSLink
10-30-2015 09:43 AM
SinCityTLX
55
10-11-2015 01:20 AM
Hines57
09-24-2015 01:58 PM
