A little how-to on chip repair.
Old 03-25-2009, 08:00 AM
  #41
ReD-BaRoN's Avatar
Originally Posted by meagain
I ordered my WDP paint just now from PaintScratch. I chose the bottles.
My only trepidation is the "tri-coat" issue. Base, mid-coat, clearcoat. One area needs primer so that's FOUR layers.
My concern is if I put too much base-coat down, then mid-coat, then sand, would I be sanding off my mid-coat? I "think" the base coat is plain and just needs a thin cover then the mid-coat is the one that will mostly fill the hole. Course the clear coat needs to fill a bit else it'll get paper'd off. Get what I mean?
Anyone know of a good site where I can order the wet Megs sandpaper? All I could find at the local stores was 3m 2000.
I followed this procedure and it worked great. I just put a few layers of NBP and sanded. I didn't put any clear on, since the instructions said that wasn't needed (and I don't think they used it in the example above) and it looks fine w/o it.
You're right that if you're going to do the clear, you have to leave a "divot" to put the clear in to avoid just sanding it off.
I would try one spot that's the least viewable and see how it goes with several layers of WDP.
Did you Google for Megs?
Old 04-23-2009, 06:24 AM
  #42
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
Nice job!
Old 04-23-2009, 09:25 AM
  #43
B A N N E D
jaysizzlecity's Avatar
Nice........
The Machine
09-24-2018 08:27 PM
bluetl04
08-16-2016 02:49 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
Hines57
09-24-2015 01:58 PM
Sixers12
ILX
09-06-2015 07:54 PM
Quick Reply: A little how-to on chip repair.
