Leather cleaning products: Spray or Goop?
Old 05-28-2005, 03:04 PM
Scoobie Specialist
dman918's Avatar
I have heard of a couple good leather cleaners and conditioners. My question is which is better: buying the stuff as a spray, or a bottle of the goop that you apply via cloth. The problem I see with the goop is that it would get into all the holes in the TL's leather. Any thoughts?
Thanks,
Mike
Old 05-28-2005, 03:10 PM
TL no more!
WolfpackBill's Avatar
If you have perferated leather (holes in the leather), you should use the spray instead of the goop.
Old 05-29-2005, 09:24 AM
The Old Grey Whistle Test
TOGWT's Avatar
Paste or spray the only thing that makes any differene between them is the product not its delivery system.
Perforated Leather:
Should be routinely cleaned using a pH-balanced, non-alkaline cleaner (6:1 Distilled water / Woolite® solution) to loosen and lift grease and grime without drying the leather or affecting the hide's natural pH.
In addition to regular cleaning, leather requires replacement of natural oils
Apply to a warm surface to help the oils penetrate (warm with the suns heat or a hairdryer) allow sufficient time (preferably overnight) for the oils to permeate the leather.
Use a product that will dry without leaving a residue in the perforations of the leather or a greasy surface.
Recommended products Groit's Leather Care or Leatherique Rejuvenator Oil
Application Methodology:
•Apply 3-4 ounces of the conditioning oil onto each of the seats with a light to medium pressure
•Best applied to a warm surface to help the oils penetrate the coating (warm with the suns heat or a hairdryer)
•Ensure complete coverage of surfaces, especially the seams
•Allow sufficient time (preferably overnight) for the oils to permeate the coating and the leather underneath.
•Buff the surface with a clean 100% cotton Microfiber towel
JonM
MrHeeltoe
20
02-23-2023 01:54 PM
hashbrown
02-18-2022 11:20 AM
08KBP_VA
10-22-2019 01:55 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Leather cleaning products: Spray or Goop?
