Leather Care?
Slicker Than Your Average
Leather Care?
What would you guys recommend for cleaning and protecting the leather in my 2007 Acura TL? I went on the Meguiar's site and they have like 8 or 9 products that sound exactly the same to me. Thanks!
There are a number of threads regarding leather care. Some of the more popular products mentioned here are Lexol, Zaino, Aerospace 303, Four Star, Poorboys & Megs. Here are a few threads to get you started (you can also use the search feature) and the following post from TOGWT has a lot of info.
https://acurazine.com/forums/wash-wax-23/leather-care-354019/
https://acurazine.com/forums/wash-wax-23/leather-cleaners-303-prodedure-354737/
Originally Posted by TOGWT
Three-Step Leather Care-
1. Cleaning 2. Conditioning 3 Ultra Violet Radiation protection
1. Cleaning- use a soft horse hair brush (Groit's Leather & Interior Brush) and/or a vacuum to remove any dust, apply a cleaning solution (Water /Woolite® or Dreft® 6:1 ratio or stronger) on to an applicator pad and apply to one area at a time (i.e. a seat back). To remove stubborn dirt or grime gently agitate the surface with a boar's hair cleaning brush (this will not harm the leather) then use a clean, damp Microfiber towel to rinse.
Maintenance cleaning- use a cleaning solution (Water /Woolite® or Dreft® 10:1 ratio) on to an applicator pad and apply to one area at a time
Notes:
With all cleaning products, always test a small, indiscrete area first to ensure it won't discolour or stain the surface, and ensure that the pH of the product is suitable for the material.
2. Initial conditioning - for the initial conditioning of uncoated leather, and/or if you are cleaning for the first time use a Leather Rejuvenator. (http://www.Leatherique.com) [Use Zaino Z-10 Leather in a bottle on coated leather] paying particular attention to area that are exposed to the most UV radiation, i.e. backs of headrests, seat shoulders, and then apply to the rest of the seating surfaces starting at he top and working your way down.
Allow the product to be absorbed into the hides for several hours on a sunny day, or overnight. Warmth makes the leather fibres pores open allowing the proteins and collagens to be absorbed readily. Park the car in direct sunlight, cover seats with black plastic trash bags, and roll up the windows to create a steam room to allow the Rejuvenator to fully penetrate into the hides.
2a. Conditioning- recommend a preventative maintenance routine three to four times a year, once prior to the winter season to prevent cold temperatures cracking the leather, and once before the heat of the summer to prevent deterioration and shrinkage by heat, which result in continued cracking of leather. In addition to regular cleaning, leather requires replacement of natural oils; Collagen-based products like Leatherique restore the lost moisture and maintain its natural flexibility. The smell of leather comes from oils evaporating out of the hide.
Conditioners are for leather which is porous, vinyl is not, do not use a vinyl product as a conditioner on leather as vinyl requires much stronger cleaning agents than leather and above all try to avoid raw silicone oil based products, as the silicone oil will dissolve the leather's natural oils and tend to make the leather sticky, silicone oils also have a very high electrostatic (static) attraction to dust and dirt particle.
1.Conditioning products should be applied to a warm surface to help the oils penetrate the coating (warm with the suns heat or a hairdryer) allow sufficient time (preferably overnight) for the oils to permeate the coating and reach the leather underneath.
2.It is possible to over-condition leather once the hide has absorbed the product it will saturate the foam and the hides stitching and may cause it to fray /disintegrate or over-clean your leather as this may lead to premature cracking and discoloration. Most leathers are treated at the tannery with a protective coating to help protect against staining. Excessive cleaning and conditioning can remove some of the protective properties. Carry a small spray bottle of water and a clean micro fibre cloth so if you ever spill something onto your leather, spray the affected area and wipe it as soon as possible, you should then treat the affected area with leather conditioner.
3.Conditioning oils will penetrate the fibres more efficiently if they are warmed first; place the plastic container in a microwave before using. For best results warm the leather also before application (vehicle heating system, hairdryer, or the suns heat Allow sufficient permeation time (4-6 hours) or overnight if possible, especially with coated or spray-on dye leathers.)
Schedule: Once every 30-60 days, Arizona, Florida and Texas, especially in summer, for northern climates between 90-120 days, use a leather conditioner to restore these natural oils and keep the leather soft and supple. (Criot's Leather Care, Autoglym Leather Care Cream, Zanio Z10 Leather in a Bottle or Zymol Treat leather cleaners are all good maintenance products)
3. Ultraviolet Radiation (UVR) Protection - you should consider additional sunscreen protection (especially if you own a convertible) leather conditioners typically do not offer any UV screening. The best solution is to alternate between a leather conditioner and a, ultra violet radiation (UVR) protection (303™ Aerospace Protectant). One month use a conditioner to keep the leather healthy and supple. On alternate months mist and wipe the leather with a UVR protection. After application allow 60 minutes for product to cure, then using a 100% cotton cloth to lightly buff surface
4. Leather Protection Cream - a water- based protector for all leather types except Nubuck. It's not a typical conditioner. It uniquely provides protection against oil, water, and alcohol based stains, as well as providing resistance to the effects of daily soiling. It places an invisible, breathable barrier between you and the surface of the leather. Unlike leather "conditioners", this cream will NOT make your leather shiny, sticky, or leave any type of film on the surface. It leaves your leather exactly like it was when new.
http://www.topoftheline.com/leather--conditioner.html
Notes:
What product fulfills the following stipulations:
1. Will remove dirt, body oils, etc. from my leather seats.
2. Will have a slight leather smell (i.e. how it comes from the factory).
3. Will give my leather seats a natural look and feel (i.e. how it comes from the factory).
4. Will be easy for a noob to apply.
I tried searching, but I couldn't find anything that fulfills the above stipulations. Thanks a lot!
IMHO:
1. Zaino Z9
2. Zaino Z10 (actually a fairly strong leather scent...but will diminish after a day)
3. Z10
4. All of the above
throw in 303 every month or so and also use 303 on the dash...you'll be very happy with it.
Former Sponsor
Obviously your going to get varying suggestions as to what works for the members here. In one respect or another, the products listed work in a discriminating fashion for its users, and I have no doubt they're all good. I have a few at my disposal, that I go back and forth to. About the only one I use "more" then others is probably the 303 protectant. However its neither a cleaner, or dedicated leather conditioner. But it by far exceeds most when it comes to protection....
All the below items can be found here, and then some!!
Ultimate Leather Conditioner
Ultimate Leather Cleaner
As for actual cleaning, i prefer just a warm water dampened microfiber with maybe just a touch of APC or cleaner. Then follow up with a yellow foam applicator for the protectant/conditioner.....
I started out using woolite and water then 303 when the seats dried. I don't have my TL anymore but I have used the Duragloss sytem Patrick(exceldetail) has showing. It really simple to use and leaves a nice finish. If you are looking for an armour all high gloss Duragloss is not wat you want. If you want a nice smooth feeling and a natural look that is not greasey<sp> the the Duragloss will be your ticket. I would follow up with 303 for protection its like sunscreen for you cars inside.
Do you have to follow up with conditioner after you clean the leather? I just have a little bit of dirt/body oil on the side support of my passenger seat that I would like to remove (all of my other seats are perfectly new). Thanks!
Former Sponsor
I used a slightly damp MF towel and very gently rubbed the dirt/body oil off. Then I went over it with a dry MF towel. Good as new!
Quick question ... Does the texture (i.e. you can feel the texture if you run your hand across it) of new leather smooth out gradually over time/use? The leather on the side supports of my driver's seat feels a little smoother than the leather on my passenger’s seat and rear seats.
I think that is the leather breaking in. Your driver's seat is always gonna feel different. Kind of like those favorite pair of shoes you always wear, unlike the pair you keep in the back of the closet that you wear when your wife drags you to a wedding.
The leather seat side supports in the 2007 Acura TL have a texture to them (i.e. you can feel the texture when you run your hand over the leather; you can clearly see the texture also) and thus have small crevasses that dirt/body oil can get caught in. Well, I have small specks of dirt/body oil in these crevasses (in a small area) that I can't seem to get out. I tried going over it with a damp MF towel and I got some of the specks out, but there are still some left. How would I go about lifting these specks of dirt/body oil out of the crevasses? Would a leather cleaner work better than the damp MF towel? Do I need to maybe use a brush instead of the MF towel? Thanks!
The leather seat side supports in the 2007 Acura TL have a texture to them (i.e. you can feel the texture when you run your hand over the leather; you can clearly see the texture also) and thus have small crevices that dirt/body oil can get caught in. Well, I have small specks of dirt/body oil in these crevices (in a small area) that I can't seem to get out. I tried going over it with a damp MF towel and I got some of the specks out, but there are still some left. How would I go about lifting these specks of dirt/body oil out of the crevices? Would a leather cleaner work better than the damp MF towel? Do I need to maybe use a brush instead of the MF towel? Thanks!
Former Sponsor
Are you talking about the seem area? Open it up with you fingers and vacuum it out.......Or are you taking about the perforated area of the seat. Ive never had any issues with TL seat cleaning.......They clean up pretty good!
Leather Seat Side Support
Leather Seat Side Support ( Close-Up )
See the small black specks of dirt/body oil in the crevices of the leather?
There's no specific time etched in stone. Some folks like to do it once a month, some 4-6 weeks, every 60 days. Is it garaged at work, how long the vehicle is exposed to the elements are some factors to consider how often it should be accomplished. There is a suggested schedule in post #2.
The Old Grey Whistle Test
Originally Posted by neodragon0l
how often do you guys use this stuff?
Ok i get the clean and condition part, but here is my question. In my 06 TSX apparently only the perforated parts of the seat are real leather. I will be using Lexol on those as soon as i pick some up tonight, but would it be recommended to use it on all the other leatherette surfaces too or should i use something else to clean that with. I want to keep the whole seat the same color/texture but is there any point of using a conditioner on plastic, will it even absorb it?
Arrush
Arrush
TSXRCR22
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
09-25-2015 06:14 PM
