How to Zaino - a detail process
never stops!
I'm sending this to one of the member in a PM thought I might post it here as well. Please disregard if it's a repeat.
You will need these Zaino products;
ZFX - fast curing agent for polish (you can skip this if you want to wait longer in drying/curing times per coat)
Z2 - Car polish
Z5 - Polish for scratches and swirls (you can skip this if you do not have scratches and swirls)
Z6 - Gloss enhancer.
Z7 - Car wash Shampoo
Clay Bar - You can also buy from Walmart or local auto parts store for cheaper
1. Strip previous wax - (15-20 mins)
What you need to do is strip any other wax you have before you begin. To do this, wash with Dawn (Blue) and water twice with one rinse in between. DO NOT dry car as yet.
2. Clay Bar (20-25 mins)
Mix water with Z7 in a spray bottle and then spray on 6" x 6" area to lubricate and move clay bar on it till all the contamination are picked up and the area is as slick as it can be. You will know this when the clay moves smoothly on the surface. Do all the car with this process.
3. Wash Car (10 mins)
Wash car again with water and 4-5 caps full of Z7.
4. Dry Car (10 mins)
Dry with leaf blower to blow water from out of behind mirror, license plates, grill, trunk and doors. Use 100% white cotton towels to dry remaining water left behind. Do not let water evaporate since it will leave water spots.
5. Apply Polish (10-20 mins)
Now you need to prepare polish by adding ZFX if you want to reduce on waiting time for curing. Add 4-5 drops per oz. of Z2. Shake well in the bottle it came with for 3 mins. Keep aside and get your towels, applicator etc. now shake the bottle one more time for 1 min and squirt a dime size on the applicator it came with. Fold applicator to spread polish on it. Put it on the car paint and apply VERY THIN coat. Do not apply more, you do not need it. Apply to whole car and wait for 30 mins for it to cure. More if you have not added the ZFX.
6. Buff off Polish (10-15 mins)
Buff off polish with cotton towel. Keep on folding towel to remove polish off.
7. Enhance Gloss - (10-15 mins)
Spray a squirt of Z6 on 1'x1' area and buff off with cotton towel.
You can do multiple coats by repeating steps 5 to 7 by switching to Z5 in between. This can be done immediately after step 7.
VERY IMPORTANT: While washing, drying, polishing, buffing always use back and forth motions on trunk, hood and top and up and down on sides. NO ROTATIONS AT ALL.
Z2 - Car polish
Need a WHAmbulance
There is already a complete Zaino process in the Common Topics & Questions.
http://www.acura-tl.com/forums/showthread.php?t=74255
This link appears to no longer be working. Are there any updates?
2016 E350 Sport
Originally Posted by Alin10123
The "no rotations" part is important. It will reduce the appearance of swirl marks. They will still be there. You just can't really see them.
2016 E350 Sport
Z2 - Car polish
Z2 - Car polish
I think it is general knowledge that Dawn dish soap should be only used on soiled dishes. This is a high alkaline soap that is designed to break up grease and oil. Using Dawn is no guarantee that all of the wax will be removed. It will definitely remove important oils from the auto paint. These oils are necessary for a deep wet looking finish. With the oils removed one may see a highly reflective paint surface but it will have little depth and richness. A good paint cleaner used with a random orbital polisher (ROP) will strip the old wax, correct swirls/scratches, and prep the paint for polishing and a last step protectant wax or synthetic.
I'm also curious how someone can wash, polish, etc. a car in 15-20 minutes. I have a very good wash procedure and I will never be able to properly wash or polish a car in that period of time. I also own a small 2Dr Civic. I would be interested in watching this process in action. I would love to save 60-75min off my normal wash time.
It really does not matter what direction you use to wash, clean, polish, or wipe off product. If this happens then Stop what you are doing and reevaluate the product you are using and the application it is being used for. Auto paint is not wood.
Good luck and happy detailing!
never stops!
Originally Posted by SweetJazz
I first want to say thanks for taking the time to put together this "Zaino FAQ". I do not use Zaino or really dislike it but I keep reading about certain techniques that I feel are not necessary or may even be harmful to auto paint.
ANyway, this is what I do you have every right to differ and use your own method.
And yes happy detailing!
2016 E350 Sport
[QUOTE=JoganJani]
It sure does, when you touch paint with anything it is going to do marring and micro scratching. If you follow up-down and right-left rule you will get the minimum swirls. I think you have a white or light color car so you have not seen much swirls. Just a guess.[QUOTE]
Actually, the reason I have very few swirls has nothing to do with the color. I'm super anal when it comes to my car so I treat my light colored car as if it were painted black. If you use proper techniques with the right products you are not going to scratch the paint such that it is easily visible. Eventually, after a period of time, it is inevitable that a few scratches appear. That is the reality of keeping a car looking good all the time. However, using a up/down, left/right, or circular motion will make no difference. I tend to use left/right motions only because it is easier on my shoulders and arms. I have tried them all and I have observed no difference.
How about an update
I have been using this process since my 03 TL, and now with my 06 ASM. Zaino has added some new products may be time to update the process. Thanks for the procedure as it makes the ASM look sweet .
Zaino Show Car Polish Releases Z-CS Clear Seal
NEWS: Zaino Show Car Polish Releases Zaino Z-AIO ALL-IN-ONE Cleaner Polish and Protectant
The Old Grey Whistle Test
Polish /Wax / Polymer Directional Application:
What makes a scratch visible is the way light reflects from its microscopic peaks and valley’s are two-dimensional and the light reflects from them differently from the rest of the paint surface. The reasoning behind hand polishing in one direction only is that unlike a machine polisher the pressure applied is not consistent, especially if you polish using circular motions. The inconsistent abraded pattern (swirls) causes light to reflect unevenly thereby highlighting the abrasions or scratches
Order of product application- hood- roof-trunk from front to back and, where practical, the quarter panels- door panels- and bumpers from top to bottom. Washing, claying and waxing that way has to do with the way light reflects off the body panels and is also less likely to show the surface marring that you will invariably make.
• Polishes- these products contain abrasives and should be applied in straight-line motions (Forget what Mr. Miyagi was teaching the Karate Kid) circular motions will cause circular directional marks (swirl marks) When an abrasive is applied by hand the pressure applied is uneven and the reflected light highlights the peaks and valleys differently.
• Polymer sealant, Glaze or Wax- these products are all non-abrasive so direction of application won’t cause directional marks to the surface.
•Machine application - when you abrade an area with a machine and a foam pad these abrasions form a uniform pattern (the machine /foam pad applies an even and consistent pressure) and light reflects from its surface evenly without any two-dimensional reflectance.
•Optimising light refraction - apply product in ‘direction of airflow’, horizontal surfaces hood to trunk, vertical surfaces front to back. This application technique affects the paints optical properties by optimising the surface light refraction and the reflectivity of the bodylines and contours of the vehicle
Originally Posted by NYZGREATST
can i use an orbital like a porter cable to buff?
Can Zaino Be Applied By Machine?
If you have a Porter Cable 7424 dual-action polisher, you're in luck! Using the 7424 polisher you can easily apply three or four coats of Zaino Z2 or Z5 (be sure to use ZFX!) in a couple hours and not break a sweat. The trick is to use a the Sonus SFX-3 Final Finish Pad. This pad does an amazing job applying a whisper-thin layer of Z2 or Z5. The layer is so thin, in fact, that very little toweling is necessary to remove the remaining film.
The secret is to first lightly mist the Sonus SFX-3 Final Finish Pad with Z6 (one light shot) before starting to buff. Apply the Z2 or Z5 in a thin plus sign across the pad. Buff with the speed dial set at 3 until the polish is distributed, then dial the speed up to 5. Apply more Z2 or Z5 to the pad when you see it's no longer applying a uniform film. After buffing the entire car, use a Concours Buffing Towel to remove the remaining polish film. Repeat as desired (up to four coats in a single day!).
Originally Posted by stryder
Correct me if I'm wrong, but doesn't using Z5 after applying Z2 will strip whatever you just applied? My impression is Z5 is a polish/swirl remover and has cleaning abilities, and Z2 is a sealant.
Originally Posted by Hawhyen51
It is a polish, but not in the context you're thinking of. Z-5 is non abrasive and contains fillers to hide imperfections while providing gloss and reflectivity.
Originally Posted by ReD-BaRoN
Unfortunately, this link is now a sales pitch for Ultima Paint Gaurd Plus. I haven't been able to find the correct link.
At the time of the post (#16), it was still a valid link. I guess the previous article about Zaino was removed and replaced with the new article when the Ultima line was introduced. If I remember correctly, the excerpt was the only mention of applying Z-2 and Z-5 using a PC.
ReD-BaRoN, I don't know if you read this thread titled Zaino 101: Confessions of A 1st Timer but it's a very detailed review of the entire process. Maybe it'll offer you some info you can use.
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
