how do i get rid of water spots?
i've searched and all i found different from what already do is a product from griotsgarage.com. has anyone used that products from there?
my problem is water spots on the windows, a lot of them. i've tried washing later towards the evening but i end up still drying after the sun is down. here are the stuff i've used:
1. stoner's invisible glass
2. windex
3. armor all glass cleaner
4. damp rag
still no good. it maybe my technique, i dunno. anyone have any tricks or out of the ordinary ways to use those products to get rid of my water spots on the windows?
thx in advance
2. windex
4. damp rag
thx in advance
Originally Posted by moreace
try newspaper or microfiber towels to wipe the cleaner off
i thought newspaper are just for eliminating streaks? i'll try it anyways.i usually start washing my car at 6 pm but by the time i'm halfway drying the sun is gone
this is what i use to clean and polish the glass
AutoGlym
it works great, it cleans and polishes the glass. my glass is crystal clear free of any smears or smudges. and absolutely no water spots. if you car is tinted don't use this on the tint its too abrasive for it and will ruin it. here is the other product that they have that is safe for tint
AutoGlym Fast Glass
AutoGlym
AutoGlym Fast Glass
oh yeah if you decide to use the autoglym just a warning it will leave a little chemical smell at first but goes away quickly. if you just use it on the exterior its not a problem but in the interior you will have to air out a bit.
AutoGlym
AutoGlym Fast Glass
AutoGlym
AutoGlym Fast Glass
Vinegar, from the grocery store. That works better than any commercial preparation and is CHEAP. It's a weak acid, so chemically dissolves (combines with, actually) the carbonates and other stuff that makes up the hard water spots. Get a damp sponge. Pour some vinegar on it - not so much that it's dripping. Wipe it on over the windows. Keep wiping, not scrubbing, for maybe 15+ seconds for each 2 sq. ft. or so area. It won't hurt the glass. Wipe off with a paper towel or whatever and check results. Repeat as necessary. If you get any on the paint, it won't cause immediate damage, but wipe it off, preferably with a wet towel or something. Use rubber glove while using.
water spots from the paint
how about water spots from the paint? im in miami so its really hard to dry the car before the sun does unless you do it really late then i cant really see as well and it doesnt come out as good. does vinegar work for that too? i have some on the back that wont come off with regular washing, theyre like embedded there...is this a job for the clay bar?
Originally Posted by w1n78
so i guess i have to get the second one coz of the factory tint? is this online order only or can i go to say walmart or pep boys?
i will try the vinegar thing (since i already have it) on the worse part of the window. i also emailed autoglym people about the factory tint question. too bad they're closed already i would've called them. thx for the tips, i'll let you know about the vinegar thing tonight when i get home from work. so it's straight vinegar and no water mixture at all?
You can dilute the vinegar with water if you want, but it will take a little longer to work. The store-bought vinegar is already diluted acid (mostly acetic acid, actually). I've never noticed the smell is all that objectionable, considering that it does the job.
Originally Posted by TLGator
Hybrid - Regarding your last post above, are you sure you're still talking about cleaning windows?
i think it is according to this post. he claims it won't hurt the glass. i'll try it on a small area where there's really a lot and wait for a day or 2 to check out the results.
By the way, I've also used it on paint itself on parts of past cars with zero problems. Flush with water and then wax the paint afterwards. (Try it on a beater or an inconspicuous spot if you don't trust it).
There are also commercial household products that will work, such as Lime Away bathroom cleaner. It also won't hurt glass (it's for shower doors among other things) but might be stronger than vinegar, which I've found to work fine.
Products based on ammonia, like some window cleaners, won't really touch the water spots significantly. That's fighting a base with a base.
Hybrid - You're not exactly letting yourself off the hook with these wiping comments, bro.
You're not scrubbing the glass with the vinegar on the sponge, just wiping over it to keep the solution in contact with the glass (water spots). For non-believers, try a water spotted house window or shower door first. It'll probably take longer than a car window because of the additional deposits and maybe time it has been on there, but it'll work there too.
The best bet is to wash in late afternoon or before dark when sun is not out. I use a window cleaner made my Finishfirst (best I have used) and good quality micro-fiber towel. If I get any waterspots from washing when hot I use a product called Nu-glass, works great. Also is good to just get windows really clean before final cleaning with the widow cleaner. Here is a link for the water-spot remover- https://www.duragloss.com/new/products/gl-cleaners.htm
Originally Posted by `ill*tl
Try using a mixture of water+vinegar.
Yes, regular white vinegar works great. I had water spots on my windshield (from a water sprinkler spray on a hot day) that Stoner Invisiglass and windex can't remove. I poured some white vinegar to a spray bottle, sprayed it on the glass and used a microfiber towel. All the water spots are gone. Ya, it does not smell nice but the odor will go away quickly.
I had water spots on the trunk and roof of my car after a hard rain. Rubbing compound was the only thing I used that took it off. 3M Rubbing Compound Fine Cut (Part # 03900)
This also works for removing light scratches in your clearcoat.
I tried doing some rock chip repair recently... worked very well the first time around (base coat, dry 24 hrs, clear coat, dry 24 hours, then smooth out using rubbing compound) but I got "perfectionist" syndrome and tried to make it even better. Ended up burning the paint in an area that wasn't even a problem. Now it looks like crap since the area where the paint burned is pretty large (about a dime) but ah well, lesson learned.
OK i tried the vinegar thing. the one i have at home says it contains 4.7% acid. so i was concerned and added some water to it. i had some meguires applicator lying around unused so i used that. i must have done it 4 times on that same area of the window but water spots still there
. should i have not added water to it? also got an email from autoglym and here's what they said:
someone also mentioned 409 which has amonia. but i tried windex, doesn't that have the same amount of amonia? but it didn't work. does the vinegar have to specifically say "white vinegar"?
If you have stubborn water spots, the best solution is Autoglym Glass Polish (http://www.autopia-carcare.com/ag-4325.html). It makes really quick work of water spots. It is safe on all factory glass (inside and out), but don't use it on window tint film
[QUOTE=xpditor42]
what claybar and where can i get it? preferrably not online coz i can't stand seeing the spots and want to get rid of it asap. but if it's online only let me know the site. also is this safe for the factory tint then again the tint is inside.
Originally Posted by go4heat[SIZE=2
]...is this a job for the clay bar?[/[/SIZE]QUOTE]
Yes.
XP
Yes.
XP
Please explain. Letting myself of WHAT hook? I didn't realize I was on the hook.
For water spots?
. should i have not added water to it? also got an email from autoglym and here's what they said:Vinegar is mildly acidic. You can drink it. It dissolves minerals and puts them back in suspension so they can be rinsed off. You probably diluted it beyond its effective range.
You can clay bar windows. I have done it two days ago. Auto stores should have it where the wax products are. Meguires sells a kit, also Clay Magic, and also Zaino (www.zainobros.com). Check www.autopia.org for online shopping.
Originally Posted by xpditor42
Water itself doesn't stain. It is the minerals in water that remain after the water evaporates that leaves spot.
W1n78 - don't add water to the vingar. Also, let it sit for a while on the glass before you wipe it off. This will give time for the vinegar to work on the dried mineral deposit.
PS: I notice a lot of times the rattle I have on the front passenger side comes from the seat belt buckle not hanging properly. It will rattle against the plastic post/pillar. Just pull on it and make sure the buckle goes as low as it can which clears the pillar. This of course assumes that it is where the rattle originates.
Gee... Where's mine?
I suspect that many of the reported rattles (not all) might come from things we have added.
Let me say that I have never been delivered a car that is in such perfect conditon as this TL. I spent 9 hours the next day after delivery polishing everything that wasn't in motion. I am very particular to the point of being obssesive. This car had zero flaws on delivery <knock on wood>. I think that is remarkable for a mass produced automobile. Kudos to Honda/Accura. I may find problems later, but today, I'm singing their praises.
XP
ok tried the vinegar thing again w/o water. i applied it 4 times in one small area of the window and it did not get rid of the water spots
. i will try the other suggestions in this thread and let you all know what i come up with.
ok here's what i did and it worked. get a slightly used steel wool, you know the ones you use to clean dishes and stuff. make sure it's slightly used so it's a little softer. then i used the armor all glass cleaner. heard there was alcohol in the ingredients so it's a little stronger. make sure you don't get it on the paint.
spray the cleaner in a small area and use the steel wool. apply pressure as needed. do not heavily scrub the area. it shouldn't scratch the window, but then again be careful. have some micro fiber towels handy to wipe off the excess window cleaner.
so far i've done small areas this morning coz i was running late for work but i'll be doing the rest tomorrow morning or the weekend.
DO NOT use steel wool on the back window coz the defrost line thingys are there (dunno what they're called
) i've only tried this in the front windshield outside.
