Hazes the following day
Hey guys, I haven't been on for awhile. Looking for some help. I was recently helping my housemate removing some tiny blemishes on his 2009 Accord. It look ok that day, but the following day, there were hazes on the spots that I was working on. I'm not sure what went wrong? I will take some pictures later tonight.
Well what was your process? Sounds like you're experiencing micro-marring, which are thousands of micro-swirls from not refining the finish enough. Go back over it with a finer finishing polish to level out the marring.
The reason you didn't see it yesterday was due to the fact that whatever you used probably contained some oils which hid it temporarily, but evaporated overnight leaving you with the true finish. If you want to avoid this, after you finish polishing wipedown the spot with a 50/50 dilution of Isopropyl Alcohol and water.
I was just polishing. Started with 1, then 3, and then 5. Which polishing pad should I buy from Pat?
could be the case. usually how long do i need to spend on a certain spot?
Use a finer pad and a finer polish, and work the spot for a bit longer. And polish until the product is broken down, it varies from product to product.
My friend took the picture:
Link to picture
After seeing pics, what are your suggestion? buy finer pad or continue to polish longer?
Link to picture
Link to picture
Link to picture
And buy a finer pad. If the paint is soft enough, it is not going to finish down well no matter how long you polish for if the pad/polish still has too much cut.
Always make sure the pad supports the product, red, is a finishing pad, and not recommended for polishing. I do all of my polishing with either Orange or White, and on rare occasions I use Yellow....
So is a white pad finer than the orange pad? I didn't use the red pad for polishing; I just the orange pad.
After polishing with the white pad again, it looks better at the two other spot. The hood is still somewhat visible, but pretty hard to tell now. I'm not sure what you mean by it's not a pigment problem?
There are certain paints/colors where the pigment actually starts to fade below the clear coat. One thinks they can cure it with some topical treatments, but when in fact, its below the surface.....Ive seen it first hand.....
