Fine Swirl Mark Removal
Hi all,
Been making mistakes washing the car lately due to lack of time, being deployed 7 months, etc. I would like to remove the fine swirl marks I now have...is it better just to get it detailed? Or can I use something like Nu Finish? I will be getting back to my 2-bucket method this spring along with ONR, waffle weave, etc so just need to fix then keep it nice.
2006 TL w/Anthracite
Hi all,
If your going to take it to a detailer make sure he is correcting not filling .. The lowest $$ deal may not be the best. If he uses heavy waxes or glazes they will be cone after a few washes.
Make sure he is polishing out the swirling and if he is using a rotary he knows what he is doing so he doesn't fill it with holograms.
Thanks everyone for the advice. I am not located in CT, currently in Vegas but reside in ID! There is one detailer nearby (military so live in a small town) that I will have to ask how he 'corrects' swirl marks. If not, it will probably be a DA polisher for me. Usually I have some caution prior to trying new things, but I have used clay bar techniques on the car with no adverse results, etc. How much is a good polisher and what products would work?
Found the 7424 on Amazon, Megs 105/205...once I finished those up, what then? wax then sealant? Read good things about blackfire....
How does it compare to this pricing?
http://www.coastaltool.com/a/port/7424xp_5polisher.htm
Blackfire is the flavour of the week .. I'd rather suggest a couple of tried and true old faithfuls ..
1) Duragloss #105
2) Meguiars #21.
Make sure its the 7424XP .. you will also need polishing pads to go with it.
1) Duragloss #105
2) Meguiars #21.
1) Duragloss #105
2) Meguiars #21.
OP, before purchasing a polisher, i suggest reading on which polisher you think my be best. I was at first going to go with a PCXP, but after reading a whole bunch of threads on autogeek and autopia about the different DA polishers out there, i went with a Griot's Garage 6" DA Polisher. More power and a life time warranty. I highly suggest autogeekonline.net (forum) and autogeek.net (online store).
Nothing wrong with a regular 7424...although it is the older version, suppose to vibrate a bit more, and a little less power.
The negative side of the Griots 6" is the pad size alone ... pads are too big to go in a lot of places.
Have you owned boththe PCXP & the Griots? Nice to get a true comparrison besides a propaganda one. BTW as far as warranty goes the average user will never wear out an XP .. I still have my first one and it did 100+ cars a year for 3 years.
I own both .... there is a big difference in power ...
Im sure the PC and PCXP are excellent machines and im not saying anything bad against them. But, its just nice to know that one has a lifetime warranty and more power. I think the warranty is most beneficial for weekend hobbiest just in case there was a defect after certain amount of use. I would be piss after spending such money and using a defective machine lets say only 6 times. Im just saying, OP should look into all the different DA polishers out there! Meguiar's has cruise control, pcxp has the history, GG6 has most power and lifetime warranty. There is the shurhold which i havent seen much talk about.
More power is always better. After using the GG6 a couple of times, i really wished i went with the FLEX DA polisher. Might just go with the flex rotary instead as an upgrade later on.
The PC I suggested comes with a 5" backing plate ...
The thing is .. I am speaking from hundreds of hours of hands on experience ... not hours of reading ..
In the hands of the inexperienced more power also gets you in deeper trouble faster.
Don't want to start a PCXP vs Other DA polisher thread, as hands on experience would triumph research anyways.
Oakes
Wash & Wax
10-12-2015 11:17 AM
