DuraGloss 105 .. first impressions.
I got a chance to use it today on a 08 Tundra that was a black pearl.
I did the usual prep right down to the PoliSeal for cleanup and light filling. I did this to see how much cleaning the 105 would do.
The 105 didn't appear to remove the PoliSeal or if it did it did the same job of filling.
I used it in direct sunlight as is my preference. I have yet to do a side by side for visuals but it seems the #21 has a little more depth & wetness. Both have excellent gloss. In a week or so I'll have a red Infinity to do and I'll split the hood between 105 & #21 to see if I can see a difference.
I am more interested in visuals as I know #21 has great durability and I hear the 105 has also.
It applied and removed easily in the sun when left on a panel up to 5 minutes. Never tried any longer than that. One thing it did was dust just a little during application and removal. Not a lot but it was there .. not enough to even require cleanup.
It seemed to compliment the PoliSeal very well.
All in all so far its was a well spent $10.
Originally Posted by bo0sty
can you explain how you clean up with poliseal, do you just poliseal right after finishing polish?
Some polishes leave a residue or oils behind and sealants like a good clean surface to bond to .
I apply the PoliSeal using a black pad and the PC set on 3 and make fast passes.
Originally Posted by dnd2984
I did the TL with 105 last week and will do the Tahoe with 105 next week. The 105 is great. It went on really easy, let it haze for about an hour. And then easy off.
Originally Posted by phee
i dont think one is supposed to buff it off. i believe it should be wiped with a MF, correct me if im wrong
