cleaning headliners
Old Nov 13, 2006 | 03:18 PM
TLBaller's Avatar
cleaning headliners
i have a 97 acura tl so im not sure if the later tl/cl/rl has the same headliner material but mine is cloth
When I drive, I usually roll down my windows and of course there is air pollution in the air which gets stuck in our cloth headliner. Is there a way to get it cleaned besides vaccuum'ing it? My interior is beige/brown but its turning grey'ish black!
Old Nov 14, 2006 | 02:32 AM
TOGWT's Avatar
The Old Grey Whistle Test
Headliners:
Require special care and attention, as cloth type headliners are assembled with foam backing and usually glued to a fibre roof panel. If the headliner becomes wet, it can cause the head liner to delaminate and fall down. An interior cleaner (303 TM Fabric & Vinyl Cleaner) should be used. Spray onto a terry towel and wipe very gently
Do not spray products directly onto head lining. Wipe lightly making sure not to leave headliner wet. Inspect and re-clean as necessary. It is better to clean twice, rather than to allow the head liner to get too wet. An alcohol based aerosol glass cleaner may also work for this operation because of its quick evaporation. Vinyl headliners should be cleaned the same way.
Methodology
•Lightly brush the headliner with a natural-latex sponge or a horsehair brush, they have very soft bristles that are gentle and is specially made for headliners or leather surfaces, this will loosen dust / dirt and make vacuuming easier (for very light dust or lint use a rolling lint brush)
•Do not use a stiff brush as you may snag or tear the headliner material
•Lightly vacuum the headliner to remove loose dust
•Spray 303 CM Cleaner & Spot Remover on to a 100% cotton terry towel
•Cleaning the headliner a quarter section at a time, use very light and even pressure on the towel to work the cleaner into the fabric. Do not saturate the material or use much pressure on the towel
•Use a fresh, clean damp, 100% cotton terry towel to remove the soil / dirt
•Frequently rinse the towel in clean warm water to ensure all dirt I soil is removed
•If the vehicle is fitted with a sunroof, open it a couple of inches, as dust build up at the front edge.
•Clean this area before closing the sunroof and proceeding to the rear of the sunroof.
{Knowledge unshared is experience wasted}
Old Nov 14, 2006 | 07:47 AM
TLBaller's Avatar
wow thanks. any idea where i can find 303 tm fabric and vinyl cleaner?
Old Nov 14, 2006 | 10:04 AM
Hawhyen51's Avatar
Check the 303 Products website and in the left hand lower menu (Main Site Links) click on "Where To Buy".
Old Nov 14, 2006 | 11:12 AM
fuzzy02CLS's Avatar
I didn't follow any of that & I never had a problem cleaning a headliner. I just used a damp soapy rag on the area & wiped it. Always worked for me.
hashbrown
Feb 18, 2022 11:20 AM
mlody
Dec 4, 2019 02:11 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Thuneau
Oct 3, 2015 04:19 PM
jmaxima03
Sep 27, 2015 10:22 AM
