Certain Grits of Sandpaper
Recently I've been detailing my sister's civic and added a bit too much touch up paint in some areas and was wondering which grit of sandpaper would be ideal in removing all that extra paint.
I have both 2000 grit and 3000 grit sandpaper but those won't do it so if anyone knows that would be great and would I need to add the clear coat on again after sanding?
Well if you sand your going to need a buffer and proper pads/polishes to get the sanding marks out. You must have blobbed it on pretty good if 2000 wont take it off.
Yea, I got all that stuff and blobbed it pretty good, would 400 grit do the job or do I need a different grade?
Dude from the sounds of it you have no idea what you're doing with sand paper. Not trying to be confrontational but clear coat is usually only 30 microns thick. 400 grit sandpaper will take that off in one swipe. Make sure it is wetsanded. First of all add some pics so we can see why 2000 or 3000 isn't doing the job. The most abrasive sandpaper I would ever use is maybe 1000 grit. Even that is very very abrasive.
With paint there is no going back. The minute you see any color on it, its too late. Be very careful sanding it down. and remember you have to back it out. So once you're done with 1000, use 2000, then 3000, then 5000 then a foam cutting pad with cutting compound then a polishing pad with polish to bring it back to stock.
Watch those before you attempt to do anything beyond this.
https://www.youtube.com/watch?v=jmEhsuO2cKY
https://www.youtube.com/watch?v=S2aC_oseMe4
dctls08 (07-07-2014)
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
