Black stuff on trunk/door caulking
I'm getting this black funk...looks like mold on the caulking/sealer around the underside of the trunk lid and around the bottom of all the doors. What should I use to remove and that's safe for paint. Sorry if this has been asked before..I searched and came up empty.
could possibly be grease leakage from the hinges of your doors and trunk
depending on what color your car is i would first just try to wash it off using hot water, if that doesn't work then take a little solvent(isopropyl alcohol) and wipe gently with a microfiber as it will scratch the clear if too much pressure is applied, obviously if your car is white or silver i wouldn't worry too much.
Mildew / Mould requires moisture to propagate find and eliminate the cause and then clean (Iz einszett 'Plastik-Reiniger') and protect (1z einszett Gummi-Pflege) the seals
https://acurazine.com/forums/wash-wax-23/diy-cleaning-hidden-gunk-56k-fail-744104/
Check out my thread on this, it seems to be road grime:
https://acurazine.com/forums/showthread.php?t=744104
SidhuSaaB
May 30, 2020 12:40 AM
nanos
Nov 12, 2015 08:41 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
