Black 04 TL Buffing/Contamination Problems
Old Nov 2, 2019 | 10:07 AM
Danky808's Avatar
Howsit Every1!
So I’ve washed and Clayed my car twice, but I’m still getting A bunch of dark colored contaminants onto my buffing pads. I’ve tried using rubbing compound or polish first. But still no luck, after the very first small section the pads still have this film of contamination’s and I’m stumped as to what this is and where exactly it’s coming from.
I’ve even washed and clayed specific areas, that way I could make sure that area had its taste of some clay and felt silky smooth before buffing. All pads are new pads that where just opened from it’s packaging. I’ve also tried using just soapy water to use as clay/surface lubricant instead of the Mother’s Auto Detailet I usually use. Oh, and the brands of polish and compound I’ve used where Meguiars and Mothers.
Any of you have any suggestions on this acid etching from Bird Shit the Owner left on for way to long? There’s quite A few spots like this with some being a lot worse then this is to?!
Ahhh Crap I’ll Take another picture of the Pads when I get home from work in A few hours. Can’t find the pictures after I typed this out haha!
Old Nov 4, 2019 | 11:58 AM
csmeance's Avatar
looks like paint failure in the first picture with the bird poop....
Old Nov 6, 2019 | 07:07 PM
MyGuti's Avatar
for the etching you can try an iron deposit remover.
I used that stuff even b4 claybarring as it does most of the work before you get out the clay.
If after using a iron remover, and a complete compound or aggressive compound, those stains are still not coming out......then you have to wet sand.
Old Nov 7, 2019 | 12:38 AM
Danky808's Avatar
The pad had A little time to dry out A little bit. But you can clearly still see all the nasty brown crap/contamination’s that collected onto the pad from the specific area that I washed multiple times and even clayed multiple times until I was completely sure that it was clean and until it felt silky smooth to the back of my hand and the clay bar!!
I just don’t understand where all this crap is coming from. Sometimes it causes A bunch of bad but still super fine swirl marks from buffing/polishing.
Old Nov 7, 2019 | 12:41 AM
Danky808's Avatar
Many recommendations on A certain product? Haven’t used an iron deposit remover before. Also, your certain I still have some clear coat to work with on the etching? I always thought those white marks that would even get polish/wax to collect into when going over, was always showing/telling me it’s gone deeper then the clear and paint and what I was actually seeing was primer or somethin like that haha!
Im super glad if I still have room to wet sand!
Old Nov 7, 2019 | 01:06 PM
MyGuti's Avatar
I used a Magma product, pretty sure its available online if its not in your local stores
I'm definitely not certain you have enough clear coat to work with, you should do your due diligence and check the level of paint
Old Nov 7, 2019 | 01:47 PM
csmeance's Avatar
Iron X works great!
Old Nov 7, 2019 | 01:56 PM
Danky808's Avatar
Oh I’ve definitely seen Iron X at my local Auto Parts Store!
So so I actually bought A Paint/Clear Reader, but it was only about 75$. So not the cheapest, but also no where near the good ones that cost thousands..
pretty sure it it isn’t accurate lol, anyone have any ways to do A field test without having access to A good tester?
detailersdomain
Wash & Wax
Aug 22, 2013 08:32 PM
rockstar143
Wash & Wax
41
Mar 9, 2010 06:26 AM
gotkilled
Wash & Wax
Oct 11, 2009 10:06 PM
JPritch
Wash & Wax
Apr 18, 2005 03:48 PM
DEVO
Wash & Wax
Jun 13, 2004 12:39 AM
