Best Touchup paint
Best Touchup paint
I need some touch up paint for my Galaxy Grey 06 Civic Si and I was wondering where the best place is to get touch up paint. And should I get a pen or a little bottle with a brush?
I got my paint pen on Ebay - just do a search for acura paint pen. You can also check out Paintscratch, they have been mentioned in several posts.
Lanka Paint chip and scratch repair
Lanka Paint chip and scratch repair technologies, is both a chemical and mechanical process, once the touch up paint has dried, The Blob Eliminator® will re-soften the paint, and the light rubbing mechanically begins to "smooth" down the excess paint, with the touch up paint now appearing on the cloth - http://www.langka.com/blob-eliminator-p-31.html
Langka and Metallic Paint-the reason metallic looks different after using the product is the metallic flakes migrate to the upper level of the paint surface while setting up. To counter this, use the blue sanding card on edge immediately after applying the touch up, like a razor. This will remove most of the touch up while the metallic flakes are still suspended evenly throughout the paint, smearing the excess across the local area. Let dry and use the Langka to wipe away the smear tail left across the original (OME) paint. - http://www.langka.com /
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
