Best Porter Cable Package? NUB ALERT.
Looking to finally get into machine detailing...
I've been looking at a few PC 7274 kits on autogeek, but I'm not sure which one I should go with.
I've use optimum products before, but not by machine. Apparently after some research, it seems like optimum should be used on cars that have been taken care of.
I'm leaning towards the poor boy package, as it seems to have a stronger compound to help me get all my swirls out.
Any input?
Any input?
Thanks, I'll keep that in mind.
There are just soo many different products its making my head go in circles.
I've washed / clayed / waxed my car before, just not with a machine. And I do have a lot of swirlies
Former Sponsor
In my book, orange, white and red 5.5" pads, 5" BP, Optimum Polish and Compound, maybe Hyper as well. Plus a sealant of your choice
Optimum products. Exceldetail
a) Small Hyper compound
b) Compound
c) Polish
Pads Exceldetail
a) 1 yellow
b) 2 Orange
c) 2 white.
d) 5" backing plate
Sealant choises.
Duragloss #105
Megs #21
UPP
thanks, i will price together the individual parts, and see if there is a difference. if its cheaper i will grab everything from exceldetail since they are a vendor here.
and dont worry, im not going to end up like that 27 y/o crybaby we had last week :P
just want my paint semi-fresh for import alliance. though my trunk has some pretty bad oxidation
Don't forget about Opti-Seal, very easy to use and looks great!! A little goes a long way! Also pick up some Duragloss Aquawax or Optimum Spray wax!! All at Exceldetail.com
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
grab a pad package from excel
fo sho.
i just need to know what kidn of products i need. i have clay, optimum compound, and some meguiars glaze. do i still need a sealant after i compound / glaze? or will wax take care of that part?
keep in mind, my car has never seen a machine detail.
should i just use what i have, or just get brand new compounds?
If you haven't pulled the trigger on a Porter Cable yet, consider the following:
Porter Cable 7424 XP - 124.99
4" Pad Kit with 6 pads and backing plate - $34.99
For under $160, it's going to be tough to beat what you get performance wise. There's no fluff in there either, simply the buffer, backing plate and pads. Smaller pads are easier to control and will break down polishes more effectively than larger pads. You can mix and match what pads you want out of that kit, simply leave a comment during checkout which colors you want, if different.
If you need a hand with anything else, please do not hesitate to ask. If you are looking for new polishes to use, consider the Menzerna line of polishes. They finish down better than any other polish I've used. Pairs up nicely with the PC 7424 XP.
George
George
Not to offend anyone ... I have the 4" pads and find I only use them for spot polishing and I mostly use the orange pad .. occasionally the yellow and the white more just for areas I can't get into with the 5.5" .
As for doing the complete car with 4" ... I hope time isn't an issue because it will take a while. As for the wool and the blue and black .. I have never found the need for them if you have the yellow / orange / white on hand.
I'd more stick with the 5.5" and if you like have the yellow and orange 4" for small spots.
Glazes are optional steps, but can help improve the depth and gloss. If you plan on using a sealant, than the glaze I've had the best luck in terms of not interfering with the bonding of a sealant is Chemical Guy's E-Z Creme Glaze.
After polishing or using the glaze, then you'll want to protect your paint with a quality sealant and/or wax. It's up to you how you want to approach that, sealants will give you durable protection for months, where a carnauba wax may offer stronger protection for a shorter period of time with some additional depth and gloss. For the best of both worlds, apply a sealant, let it cure for 24 hours, then top it with a carnauba wax.
Regarding the 4" sized pads, you're going to achieve more correction and better results with smaller pads. You're concentrating more power and energy in a smaller area, which allows you to effectively break down the abrasive particles in the polish. The main reason people do not achieve the results they are looking for is because they are unable to properly break down a polish. Invest in some quality lighting, follow the steps on our polishing guide and you will not be dissappointed with your results.
Let me know if there's anything else I can help with.
George
my paint is in pretty bad shape (NBP), i have to first get rid of water stains that have been on the hood for god knows how long. i'm assuming a little vinegar / water solution would take care of that?
anyways, i'll probably just purchase the buffer / pad kid you listed above. i still have some optimum compound i bought a year back, but i may purchase a sealant.
i'll use what i have first, and if im not satisfied, i'll try out the menzerna line of products.
thanks again for your help.
Former Sponsor
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Worse case scenario, theyre etched, and would need some leveling which a product like Hyper Compound could help out with. At any rate, any compound on darker surfaces will mar the surface requiring additional polishing steps. Severe water spotting usually requires a 3 step polishing regimine on darker colored vehicles.
Your getting a lot of things thrown at you here which is probably going to fog your decisions!
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Im going to step back and let the forums participants assist you, if you need anything further, Im just a PM, email, text or phone call away.
rcs86
08-02-2016 06:52 PM
GWEEDOspeedo
01-15-2016 10:39 PM
