Aftermarket wheels
Most modem automotive wheels have a painted aluminium base with two or three clear coats applied (on the ‘front’ of the wheel but not the back, these are usually just a primer paint surface) and are subjected to similar type contaminants as the paint film surface, including acid rain, airborne pollutants, alkaline water as well as road tar debris.
Clean, properly conditioned wheels, tyres and fender wells greatly enhance the overall appearance of your vehicle. Today's wheels come in a variety of materials and finishes. Clean one wheel at a time, wash wheels and wheel-wells before the rest of the vehicle to avoid dirt and etc. coming into contact to newly washed surfaces.
Once the brake dust has been removed with a 100% acid-free wheel cleaner, apply a citrus based cleaner to the surface, agitate with a boars hair wheel brush and rinse off, dry thoroughly and then apply a polymer sealant for protection, this will also make future cleaning easier. A polymer is recommended (ZoopSeal) as it has a higher melting temperature (350oF) compared to Carnauba wax (180oF) a wheel surface will reach a temperature in excess of 120oF due to rotor friction and in excess of 195oF when parked in the sun.
Periodically remove the wheels (one at a time) to enable the back of the wheel, callipers and give better access to the wheel wells. Should the wheel surface have small scratches they can he removed with a mildly abrasive polish.
Tar should be removed with a solvent type cleaner (and #0000 synthetic steel wool if necessary) and any bonded contaminants or over spray removed with Detailer's Clay, then clean surface with a chemical / polish (Klasse AIO) wash and dry wheel surface thoroughly. Note- Clay is not recommended on wheels that do not have a factory clear coat or powder coat finish
JonM
JonM
trinikidcl
09-04-2015 12:56 AM
