FAQ: Suspension & Brakes
2004-2005 Standard Equipment
Suspension: 4-Wheel Independent Double-Wishbone/Multi-Link Rear Stabilizer Bars, diameter (front/rear): 26.5 mm / 14.0 mm Spring Rates Front:280 lb/in Rear:175 lb/in Brakes: 4-Wheel Disc with ABS (front/rear) 11.8-inch ventilated/ 10.2-inch solid Vehicle Stability Assist (VSA) with Traction Control is standard on all TSXs. VSA and Traction Control can be fully disabled by pressing the VSA button to the left of the steering wheel. |
Alignment Specs
Caster angle: 13'± 45' (Maximum difference between right and left side: 0°45') Camber Angle Front: 0°00'± 45' Rear: 1°00'± 30' (Maximum difference between right and left side: 0°45') Front toe-in: 0 ± 2mm (0 ± 1/16 in.) Rear toe-in: 2 ± 2mm (1/16 ± 1/16 in.) Turning Angle Inward: 35°15'± 2° Outward: 29°38' (reference) |
Suspension Upgrades
Spring rate thread (all manufacturers): https://acurazine.com/forums/car-talk-5/bmw-lovers-read-haaaaaaaaaaa-40499/#post457374 Setup info and photo gallery: https://acurazine.com/forums/showthread.php?t=18474 LannyM's A-Spec review: https://acurazine.com/forums/showthread.php?t=1441 A-Spec installation: https://acurazine.com/forums/showthread.php?t=20174 Koni availability and information: https://acurazine.com/forums/showthread.php?t=7921 Mr. Heeltoe's "Do I need a camber kit? thread: https://acurazine.com/forums/showthread.php?t=34452 |
Brake Upgrades
Moda_Way's Brembo rotors/Ceramic Matrix pads/SS lines review: https://acurazine.com/forums/showthread.php?t=23558 cmf's list of available brake upgrades: https://acurazine.com/forums/showpos...99&postcount=8 De-Mystifying the Warped Rotors Issue: https://acurazine.com/forums/showthread.php?t=19175 Cross-drilled vs. Slotted rotors: https://acurazine.com/forums/showthread.php?t=24063 Brembo GranTurismo Kit: https://acurazine.com/forums/showthread.php?t=24311 |
