FAQ: Maintenance
Photography Nerd
FAQ: Maintenance
Normal Maintenance Schedule
For normal driving conditions
The "normal" schedule is fine for most drivers, even if they occasionally drive in severe conditions.
10,000 mi/16,000 km Scheduled Maintenance
Replace engine oil.
Rotate tires (follow pattern on page 276 of your owner's manual).
Check engine oil and coolant at each fuel stop.
Check and adjust valve clearance, cold engine, only if noisy.
20,000 mi/32,000 km/1 yr Scheduled Maintenance
Replace engine oil.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie-rod ends, steering gearbox and boots.
Inspect suspension components.
Inspect drive shaft boots.
Inspect brake hoses and lines (including ABS).
Inspect all fluid levels, condition of fluids and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
30,000 mi/48,000 km Scheduled Maintenance
Replace engine oil.
Inspect drive belt.
Replace air cleaner element.
Replace dust and pollen filter.
40,000 mi/64,000 km/2 yrs Scheduled Maintenance
Follow 1 yr scheduled Maintenance cycle.
50,000 mi/80,000 km Scheduled Maintenance
Replace engine oil.
60,000 mi/96,000 km/3 yrs Scheduled Maintenance
Replace engine oil.
See information on maintenance and emissions warranty, last column, page 233 in your owner's manual.
Inspect drive belt.
70,000 mi/112,000 km Scheduled Maintenance
Replace engine oil.
80,000 mi/128,000 km/4 yrs Scheduled Maintenance
Follow 1or2 yr scheduled Maintenance cycle.
Replace engine oil.
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace engine oil.
Photography Nerd
Severe Maintenance Schedule
Follow the "severe" schedule only if you drive in one or more of these conditions most of the time:
* Trips of less than 5 miles (less than 10 in freezing weather)
* Extremely hot weather (over 90 degrees F)
* Extensive idling or stop-and-go driving
* Trailer towing, car-top carrier, or mountain driving
* Muddy, dusty, or de-iced roads
5,000 mi/8,000 km Scheduled Maintenance
Replace engine oil.
Replace engine oil.
Lubricate all hinges, locks and latches.
15,000 mi/24,000 km Scheduled Maintenance
Replace engine oil.
Replace engine oil.
Check all lights.
Inspect the underbody.
25,000 mi/40,000 km Scheduled Maintenance
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace dust and pollen filter. (See Dust and Pollen Filter on page 270 of your owner's manual for replacement information under special driving conditions.)
35,000 mi/56,000 km Scheduled Maintenance
Replace engine oil.
Replace engine oil.
Check all lights.
Replace engine oil.
Replace engine oil.
Replace engine oil.
Replace engine oil.
Check all lights.
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace engine oil.
Replace engine oil.
Check all lights.
Photography Nerd
Other Maintenance Threads
Dom's "Who's Done Their Own Oil Change" thread:
https://acurazine.com/forums/showthread.php?t=3512
Pollen Filter Info:
2004-08: https://acurazine.com/forums/acurazine-clubs-meets-15/car-meet-houstonians-39992/
2009: https://acurazine.com/forums/2g-tsx-2009-2014-143/diy-cabin-air-filter-replacement-%2Apics%2A-686281/#post9971752
Replacing Engine Coolant:
https://acurazine.com/forums/showthread.php?t=31475
https://acurazine.com/forums/showthread.php?t=37966
DIY Front Brake Pads:
https://acurazine.com/forums/showthread.php?t=25642
https://acurazine.com/forums/showthread.php?t=25642 + SS lines & rotors
Brake Fluid Bleed/Flush:
https://acurazine.com/forums/showthread.php?t=35508
6MT Transmission Fluid Change:
https://acurazine.com/forums/showthread.php?t=27390
5AT Transmission Fluid Change:
https://acurazine.com/forums/showthread.php?t=27875
https://acurazine.com/forums/showthread.php?t=37261
https://acurazine.com/forums/showthread.php?t=33672
Power Steering Fluid Change:
https://acurazine.com/forums/showthread.php?t=30087
https://acurazine.com/forums/showthread.php?t=35264
Wiper Blade Replacement:
2006-08: https://acurazine.com/forums/1g-tsx-2004-2008-124/2006-2008-wiper-blade-replacement-diy-part-s-%2Apics%2A-701505/#post10297095
Pollen Filter Info:
acuratl26
04-23-2020 07:30 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
