Originally posted by NSX4DR 1.Alstadt 2.18 x 7.5 3.+53mm 4.Kumho 5.225/40/18 6.3" drop 7.Doesn't rub at all 1. Enkei Aegis 2. 19 x 7 3. +45mm 4. Toyo Proxes FZ4 5. 235/35/19 6. 2.5" drop 7. Only rubs w/4 people on bumps....... |
1.Brand of Rim:RacingHart C5 3piece/VolkRacing GT-P Diamond cut
2.Rim size: 18" by 8" / 17" by 7" 3.Offset: 52 / 44 4.Brand of tire: Pirelli P7000 SS / Sumitom HTRZ II 5.Tire size: 225/40/18 / 225/45/17 6.Drop amount: Comptech 1.5 7.Do they rub.: No/No |
Originally posted by TL Daddy 1.Rim size = 18" x 7.5" Versus Turismo Spada = 26 lbs. 2.Offset = +52mm 3.Brand of tire =Michelin Pilot Sport 4.Tire size =225/45/ZR18 5.Drop amount =1.5" Comptech springs 6.Do they rub = Only the outside corner edge of my front tire (that's on the turning side) will rub on the plastic inside the front fender if I hit a dip or steep driveway too fast with my steering wheel turned all the way to one side - when the dampers & springs compress and the weight is on the front. So I try not to do that. That's cuz I got 45 series tires and they're .29" taller than stock. I need to get stiffer shocks or coilovers? |
1.Brand of Rim
2.Rim size 3.Offset 4.Brand of tire 5.Tire size 6.Drop amount 7.Do they rub. 1. CL Type-S Wheels(made by Enkei) 2. 17x7 3. 55mm 4. Dunlop SP9000 5. 225/45/17(soon to have 235's..no they don't rub either) 6. Comptech 1.5" front, 1.25" rear 7. Zero rubbing whatsoever. Ed |
18x8.5 Giovanni Essens Chrome
225/40 18ZR Parada's 45+ offset Apexi Coilovers w/ WW kit dropped to th floor and no rubbin:eek: |
BLITZ Technospeed Z2
18x8 +45 offset Pirelli P7000SS 225/40/18 H&R SportSpring 1.75" 1.5" no rubbin |
1. Lowenhart BR5 (chrome)
2. 18x8 3. +50 4. Toyo Proxes T1-S 5. 225/40/18 6. H&R Sport Springs 7. no rubbing |
1. 5Zigen Copse
2. 18x7.5 3. +49 4. Pirelli P7000SS 5. 225/40/18 6. Comptech Springs 7. Nope. |
1. AME Modelart
2. 18 x 7.5 3. +47mm (shop claims to have customized from a +45) 4. Pneumann (never heard of this brand; think i got jacked) 5. 225/40/18 6. Eibach Prokit (2.1" , 1.65") 7. The rear rubs (after cutting out all the tabs no more rub) In my opinion: Note: Some people are running 18 x {8} with a 45+ offset with no rub on 225/40/18 w/ drop. How are you guys getting away with no rub? For those who are uncertain of wheel offset i recommend not going with anything smaller than +47 on my setup (above) if you do not want to have your tires rub. FYI : I got 35spf titanium tint. For those people with NAV i repeat DO NOT GET TITANIUM TINT ON THE REAR WINDOW! My nav is out of whack now I must strip the tint. :mad: |
1.Enkei AKA'z
2.17X7.5 3.+39 4.NT450 225/50/17 5.No droppage 6.Yea it did scrub, because i was concerned about premature miles being added to my car... I think ill drop to 225/45 when I get my new tires... I did fix the scrub in tha back with a dremel and it doesnt scrub anymore, the only thing it did scrub was rubber from the top part of the rear bumper... I shaved it and it looks nice, you cant even tell...Shyne;) |
1. Volk Racing GTP
2. 18x7.5 3. +49 4. Pirelli P7000 5. 225/40/18 6. H&R Sport 7. No rubbage whatsoever (w/ 4 people in the car) http://home.earthlink.net/~snoh/reargap.jpg |
1. Panther 175
2. 18x8 3. +43 4. Pirelli P7000SS 5. 225/40/18 6. Ground Control Coilovers- 3" drop 7. No rubbing whatsoever after cuttin the little fender tabs even with 5 people in the car! I was pretty surprised that I didnt have to roll the fenders or anything like that. Most people said it would rub and it doesn't. |
1. Giovanna Corsica
2. 18x7.5 3. +45 offset 4. Toyo T1-S 5. 225/40 6. Comptech Springs 7. no rubbing, no cutting |
1 Kosei Seneka
2 18x7.5 3 not sure-bought from the Acura dealer 4 Kumho 225/40 rubbing when 2 adults in back when going over a speed bump |
Nice wheels guys, keep them coming... :D
robbdogg: You got a pic of your ride w/ 5zigen Copse rims on..... I am thinking about getting them myself.... just like some pics for reference. Thanks! :D
1. Momo Quasar 2
2. 17X7 3. +45 offset 4. Michelin Pilot XGT H4 215/50/17 5. Stock suspension 6. Rubbing with two passengers going over bumps I guess I'll have to cut or file down the bumper tabs in the rear wheel well. |
1. stock TLS
2. 17X6.5 3. +55 offset I think 4. Firestone Firehawk SZ50 245/45/17 5. Stock suspension 6. No rubbing |
Can folks please post the weight of the wheels if you get a chance?
1. KONIG VERDICT
2. 18 X 7.5 3. + 45 4. KUMHO ECSTA SUPRA 712 5. 225/40/ZR18 6. 1.75 FRONT, 1.5 REAR 7. NO, NOT SO FAR |
1.Rim size: (19" X 8" Axis SE7EN's)
2.Offset: (+40, but +45 is available and probably better) 3.Brand of tire: (Falken ZE-502 cheap, but very impressive) 4.Tire size: (235/35/19) 5.Drop amount: (Comptech springs, initial drop was 1.5" front and .75" rear, waiting to see if they settle) 6.Do they rub. (had to cut a VERY small part of the plastic on the rear part of the rear inner fender well, now there is absolutely no rubbing, +45 to +48mm may prevent it completely without cutting) 7.Weight: (28 lbs w/o tires.) |
Blitz Technospeed Z1 (3piece forged, of course)
19x8 (front) 19x10 (rear) +45 offset (front and rear) Nitto NT555 235/35zr19 (front) 265/30zr19(rear) Eibach ProKit (1") drop No rubbing:D on order: HRE 545 (3piece forged) 19x8.5 (front) 19x9.5 (rear) +45 offset (front and rear) Bridgestone Potenza S03 245/35zr19 (front) 275/30zr19 (rear) same drop |
Lexus_IS300... Hey, all those specs... on your IS300 or do you have a TL also? ... by the way, no punt intended... with my user name.... Do you have any pics? (regardless of the car). I so some Blitz wheels on a CL-S the other night... "Man!!! they're sweet!!!!"
actually it's all in the sig
volk racing f-zero kuwagatas, 18x7.5, +42mm
pirelli p7000ss, 225/40/18 eibach pro-kit, 2.1"/1.6" rubs a little bit mostly at left rear tire (will take care of it soon) |
there's a picture of my car and i at my site www.johnlai.net somewhere. it was back when i first purchased it. ill have a few new ones along with my s4 soon.
Wheels: Zenetti saphire
size : 18X8 +42 offset Tires: Toyo proxies 224/40/18 Drop: 2.5 inch,eibach pro kit,koni sports(yellow) Rub : No rubbing whatsoever |
the wheels on the car
kk939, those are GREAT !
You did mean your tires are 225s, right? No rubbing, either... sweet. Damn I need new wheels. |
Originally posted by SimTypeS kk939, those are GREAT ! You did mean your tires are 225s, right? No rubbing, either... sweet. Damn I need new wheels. |
19x7.5 SSR Agle Minerva
Dunno offset, i think +42 or +47 Nitto 225/35/19 no drop yet nope http://www.speedstar.co.jp/collectio.../images/02.jpg |
1.Racinghart M5 3 peice
2.19x7.5 3.+51 offset 4.Yokohama AVS sport 5.235 35 r19 6. .75 inch drop 7. no rub even with 5 people. no cutting or rolling needed. |
Re: Post Specs Here......
[QUOTE]Originally posted by adamyankee
[B]Why doesn't everyone post their 1.Brand of Rim 2.Rim size 3.Offset 4.Brand of tire 5.Tire size 6.Drop amount 7.Do they rub. http://www.dazzmotorsports.com/graph...iz_wheel_2.jpg -DAZZMATIZ -19 X 8 -48 OFFSET -TOYO PROXES -235/45 -1.75 EIBACH PRO KIT -ROLLING FENDERS THEY ONLY RUB WHEN PEOPLE IN BACK SEAT AND HARD TURNS. |
1.Rim size: 17x7 Momo Quasar II (Chrome)
2.Offset: 45mm offset 3.Brand of tire: Bridgestone Potenza S-02 Pole Position 4.Tire size: 235/45/17 5.Drop amount: Comptech Drop Springs 1.25" front, 1" rear 6.Do they rub: Yes, I need to get the rear qtr panel lip roled. 7.Weight: Don't know |
Originally posted by NSX4DR Update....... 1. Enkei Aegis 2. 19 x 7 3. +45mm 4. Toyo Proxes FZ4 5. 235/35/19 6. 2.5" drop 7. Only rubs w/4 people on bumps....... |
Originally posted by BLUETYPES Where did u get a 19*7 +45 offset from |
what is offset??? I just bent my stock tl-s rims I'm thinking of going with
18x7.5" 225/45-18 do I need an offset? I sawsome wrote "comptech" as their offset, what is this? HELP I talk to the dealer about the arrangement today |
1.Brand of Rim-- Volk Av3
2.Rim size--18x8 3.Offset-44 or dunno 4.Brand of tire---mich. pilot sports 5.Tire size--235-40-18 6.Drop amount ---1.75 front and back 7.Do they rub- Yes they rub but not badd. front and back. shaved rear plastic and rolled fender. need to get new tires.. |
1. RACING HART C2'S 3-piece
2. 19x8 3. +50 4. Toyo Proxes FZ4 5. 225/35/ZR19(front) 235/35/ZR19(rear) 6. 2.7 (front) 2.4 (rear) 7. YES only before I got the knife and started hacking away:D now it only rubs on some turns. There would be no rubbing if the rear tires were 225 not 235:mad: |
1. "Rezax II" wheels forged 3 piece by "Work" (same wheel on the yellow car in "The Fast and the Furious") www.work-wheels.co.jp
2. 19X8 3. offset 51mm 4.Nitto 555 (something like that... all I know is there are 3 "5" in it) 5. 235/35/19 6. 1.75 drop front and back 7. The people that installed my springs (Wheel Warehouse in Anaheim, CA www.wheelwarehouse.com ) told me that there might be some minor"trimming" before they started the work... I agreed to it... when I saw my car after it was done... I couldn't even tell where they had "trimmed." They had to point them out... They were very minor... at no extra charge. So, NO... there are NO rubbing at all... even with people in the back... it was good that I didn't go any lower than 1.75" drop... I didn't want that... "low rider" look. |
