"Performance" air filter hype
#82
Originally posted by harddrivin1le
But the quantifiable differences are only ~ 1/10th of a psi.
#84
An air scoop moving @ speed in a ram air system slows the air...
That results in higher pressure (@ the intake manifold).
P1V1 = P2V2
P1V1 = P2V2
V is volume for a GIVEN MASS dumbass, not velocity.
You claim to have taken fluids but don't know applications in Boyle's Law?
Jeez man.
#85
Originally posted by Skeedatl
BZZZZZZ, wrong.
BZZZZZZ, wrong.
Pressure 1 * Velocity 1 = Pressure 2 * Velocity 2
http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html
#88
NO
Pressure 1 * VOLUME 1 = Pressure 2 * Volume 2
for a given mass
This is the Combined Gas Law.
NO
for a given mass
#90
Originally posted by Swat Dude
Nothin' like jumping in with such a profound statement. Maybe someone about to drop $40 on a KN filter.
#91
THIS IS THE BERNOULI EQUATION DUMBASS!!!
READ THE FRIGGIN LINK YOU POSTED. THIS IS THE FORUMULA.
You posted the combined gas law.
Man are you lame.
Man are you lame.
P1 V1 = P2 V2
#92
Originally posted by adam209
40 bucks!? hahahaha...c'mon. this entire thread is b.s. who really cares about which one allows more air or dust particles in? give it a damn rest. 3.5 pages of bickering back and forth like school children
#94
Can you read?
Can you read?
#97
I've said BERNOULI ~ 3 times...
P1 V1 = P2 V2
P1 V1 = P2 V2
#98
Let's go over this again.
Combinded gas law
Bernoulli's Equation
Combinded gas law
Combinded gas law
Holy crap!
Combinded gas law
Combinded gas law
Combinded gas law
Holy crap!
Pressure 1 + Velocity 1 does NOT equal Pressure 2 * Velocity 2?
#100
Combined gas law.
V is VOLUME
P is PRESSURE
V is NOT velocity.
Combined gas law.
V is VOLUME
P is PRESSURE
V is NOT velocity.
Are you telling me that:
#103
#105
YES OR NO?
YES OR NO?
Look at Bernoulli's principle. Velocity is squared. They are not linear relationships.
But like you even understand the difference between linear and non-linear relationsships.
#107
I can't wait...
F=ma
e=m x c x c
Do I seem smarter now?????
I can't wait...
F=ma
e=m x c x c
He's confusing the Combined Gas Law with Bernoulli's Equation, yet he claims to have taken a year of fluids.
The classes in fluids he took were at the local bar...then he came right home to start posting.
I would actually respect him a bit if he would just admit he f-ed up and confused the formulas. Fluids is hard, the math forumlas are difficult to keep straight and the logic counterintuitive. I got mostly A's with little effort in college, and I had a hard time in fluids. Sh!t just doesn't work in fluids like you think they would.
But I'm guessing he will continue taking his screwed up logic and incorrect statements and defending them to the bitter end.
#108
NO.
NO.
Harddrivin,
Which bullet has more foot-lbs. of energy?
9mm, 115 grain bullet traveling 1500 feet per second or...
.45 cal., 230 grain bullet traveling 950 feet per second?
#110
We're all waiting for your new math 1LE?
Or are you ready to just admit you screwed up?
Look, I bag on ya quite a bit, but it's because of crap like this. You should STICK to what you know. If you have an article, post it. But if you don't understand it, don't bother trying to defend it. Articles aren't gospel, especially in Hot Rod.
I encourage you to drop the mags, get off the forums, buy a helmet and go to your local drag strip and put that 1LE to work. You'll meet new people and learn REAL sh!t...speed secrets you will NEVER find in any magazine.
Join the sport instead of just reading about it. With the 1LE, you're 90% there.
#111
Torque would require a focal point like holding the subject by the neck and shooting him in the nuts.
http://mysite.elixirlabs.com/index.p...2665&page=1609
#112
Not me, I'm into spreading out the force. High velocity ammo goes through the perp, and through the 3 or 4 things behind him.
IMHO, high velocity ammo is more dangerous to people other than the perp.
Also if you use say a wad cutter, the higher velocity keeps the shape of the bullet better. A deforming bullet (bigger dia) is what gives you your stopping power not the velocity.
But I'm referring strickly to home defense situations, not police work.
#114
Either he's surrendered, or we're in full one hellofa cut n paste If he would just admit that he screwed up...I'm willing to explain the principles to him. But we have to get past the "defense" mechanism he builds up.
There is so much he can learn for more experienced people on the forum, not just about the TL, but other stuff. There are drag racers like me on here, I'm sure guys (and gals) going way faster than I am here, guys with blowers, guys who autocross, mechanics, engineers, everything.
But you have to have an open mind and be willing to learn from someone.
#115
One more test, which penetrates more gyp board, 9mm handgun round fired from a H and K MP5 or .223 rifle round fired from an AR-15?
The answer is the high-velocity .223 penetrates less gyp board than the 9mm but goes right through a bullet proof vest.
#116
But hollow point's offer lower PSI for a given velocity, isn't that what counteracts the high velocity?
What's gyp board and do you have good links for this stuff?
I figured the .223 goes though because of the tiny surface area of the .223 translates to way more PSI than 9mm allowing it to go through.
#117
I'll find what I'm looking for and when I do I'll post it.
#118
BZZZZZ.
I had you on ignore until today. Otherwise I would have continued explaining why aluminum heads can build way more power.
While iron heads keep heat, they keep it during non-combustion cycles, increasing detonation.
You can run higher compression with aluminum heads thus building more power than is lost through aluminum heads not keeping the heat.
I never said that for a given engine, you take off iron heads, and put on aluminum that you will build more horsepower. I said aluminum allows you to build more power because you can run more compression.
Take the LT1 for example. The reason they can run 10:1 was because they went to reverse flow cooling, keeping combustion temps down during non-ignition times. Controlling detonation.
If you put iron heads on that LT1, it would detonate, you would not be able to run 10:1 with iron heads on that motor on pump gas. You would have to lower the compression (and reduce the time advance), and the loss of compression is more "lost" power than you would gain by holding in the heat.
If you have say a 9:1 motor with iron and there is no detonation, the iron headed motor should make more power than an identical aluminum head because of the trapped heat.
#119
Firstly, P1 + V1 cannot be equal to P2 * V2, even from a simple units comparison.
Secondly, even correcting the typo does not make it correct. Bernoulli's is as posted by Skeedatl. Even someone with a very rudimentary course in fluid mechanics should know this. Please read a book in basic fluid mechanics first.
YES OR NO?
YES OR NO?
#120
But that's your problem 1LE. You just post links without understanding the WHY behind what you're taking from others.
You lack a FUNDAMENTAL understanding of the crap you're trying to defend.
Instead of FIGHTING everyone, how about LISTENING for change. Get your OWN understanding instead of posting irrelevant links that you don't understand.
For God sake drop the magazines and go to the track. Talk to racers so you can ask questions when you don't understand something.
