Notices
TL/TLX Frequently Asked Questions No New Threads Please.
dx6 project
Old 04-08-2003, 07:30 PM
  #41
Registered Member
:p
Thanks, I'm not sure if Ishould "risk" addind an Amp to the front...
Having read about the whine and hassle of this install ...
Anyone have a good Amp installed that drives the DX6's ?
Phil
BlackBeauty is offline
Old 04-08-2003, 10:34 PM
  #42
Registered Member
Originally posted by BlackBeauty
:p
Phil
i didnt know there was a whine problem when installing amps. is it tied to the dx6 project? if so, then you'll want to get SB to respond w/a possible solution.
systek is offline
Old 04-11-2003, 03:09 AM
  #43
Registered Member
BlackBeauty,
The problem with keeping the stock HU and adding an aftermarket amp, is that PART of the stock EQ must be bypassed in order to feed the new amp and new speakers with a flat response. The Blose HU/EQ uses floating grounds with differential inputs and outputs as well as a compressor. Engine whine and electrical noise can easily enter the new system if the bypass technique is not strictly followed.
Below is a link to the thread where Iggy and I solved the EQ bypass electrical noise problems. You will lose around 6db of overall volume in the process, but that can easily be made up for in the following amp.
Sorry for the long thread link, but it might help you to better understand the potential problem and solutions that were worked out by reading the entire thread. It also includes a good schematic drawn up by Iggy after we finally achieved success. It's definitely worth the effort if you're adding an extra amp! Lose that blose...
http://www.acura-tl.com/forum/showth...ghlight=bypass
Good Luck!
Southbound
Southbound is offline
Old 04-11-2003, 10:46 AM
  #44
Registered Member
hey southbound.. I was going to pm you but there no pm button ?? so I'll ask you here.. I need the pdf again to rehost it if you can get it to me thanks
magiviper is offline
Old 04-12-2003, 03:07 AM
  #45
Registered Member
mag,
I never actually had any files, either jpeg or pdf that were related to the mods. Other nice people here created them for me, and helped to create the sticky.
Iggy was the one who came up with the schematic for the EQ bypass. He made a complete set of new schematics with instructions after we performed the work in the thread I linked above. Hopefully he can re-send them to you? I'm sure he still has updated files of the proper EQ bypass method.
Thanks for the help!
Southbound
Old 04-12-2003, 07:24 PM
  #46
Registered Member
oh yeah thats right.. yeah iggy please send to the e-mail in my sig
Old 04-14-2003, 12:16 PM
  #47
Registered Member
Iggy's Avatar
Ummmmmm, welllllllll, I'm kind of at a loss . I never got around to compiling all the info together into a single pdf, so someone else must have done it. Where did you get it originally? If you do come accross the mysterious PDF file I could host it.
Iggy
Iggy is offline
Old 04-14-2003, 05:00 PM
  #48
Registered Member
well then who sent it to me? lol I can't remember.. ok I'll search some old back-ups and see if I can find it I think I might be able to
Old 04-25-2003, 11:51 AM
  #49
Registered Member
Thanks Iggy
Thanks SouthBound
Thanks all radio-heads
I will post my results once the Amp is added to my Polks
I already have an Amp and Sub in the trunk -Nice
:flamer:
Old 06-20-2003, 09:51 AM
  #50
Registered Member
Unhappy
the link for the mods is down can someone send me another link?
desco10 is offline
Old 07-03-2003, 11:32 AM
  #51
Registered Member
wow its been a while sorry guys.. I no longer have the pdf so I can't repost it does anyone have it?
Old 07-19-2003, 11:04 PM
  #52
Registered Member
Sask32TL's Avatar
pdf file
Sorry for my loooong absence.
My Mom passed away in April, and I have had a ton of work to do with estate arrangements. I'm finally at the point where I have more than a half hour a day on the computer.
I'm the one who re-created the schematic with Visio, added Y2KWPDTL's photos and compiled them into the PDF file.
I just read the message tonight and sent you the file via e-mail.
Too bad I didn't see the message a lot sooner...
Sask32TL is offline
Old 07-21-2003, 02:21 PM
  #53
2018 TLX A-SPEC
I-MOD's Avatar
Please post the link here once it's rehosted!
thanks
I-MOD is offline
Old 07-21-2003, 11:19 PM
  #54
Registered Member
Anyone interested in doing the DX6 mod, please let me know if you need a pair of DX6. I bought a used pair off Ebay awhile back for back up but I don't think I'll be needing it...the true is these suckers ain't going to break down i think...anyways, they are slightly used by the previous owner..I think he said he installed it and run it for a week or so then upgraded to something else. I've never used them since I bought them..if you need them, they're yours for $75 shipped..the price I bought it. Thx.
randomwalk101 is offline
Old 07-23-2003, 12:04 AM
  #55
Registered Member
Hey Guys, sorry to be such a nag, but I would like to confirm that changing the stock front speakers of the TL Type S will make a huge improvement to the sound. Is this a fair statement? Will I be able to hear the difference with the DX 6 speakers?
TLS aspec is offline
Old 07-25-2003, 01:36 AM
  #56
Registered Member
Oh Yeah, You'll definitely hear it. The problem is.... once you start with one upgrade it will never be good enough, and you will be searching for the next better upgrade.
These speakers are probably very hard to locate these days, and I'm sure there are several alternatives... but these were the easiest to tweak to your personal taste and cheap because they were being discontinued a year ago.
Good luck with whatever replacement speaker/system you end up going with. ANYTHING is better than the stock blose. It just depends upon how much money and mod work to the door panel, door frame, spacer, etc. that you are willing to perform.
Good luck...
Sask, I'm very sorry for your loss. I lost my mother two years ago, and it's still a struggle some days....
Southbound
Old 08-10-2003, 05:11 PM
  #57
Registered Member
I have read lot of info here but can anyone confirm that it is ok to do the mod to a 2003 TL (not type S). Thank you.
ash213 is offline
Old 08-14-2003, 02:37 PM
  #58
Registered Member
any news on getting the instructions hosted again? Thanks in advance.
khalils is offline
Old 08-14-2003, 06:39 PM
  #59
Registered Member
Sask32TL's Avatar
I have the PDF file you're looking for. I re-sent it to Magiviper a while back, but he's probably busy with other stuff. If he hasn't had a chance to post it again, no problem...
I am attempting the file attachment thing for the first time here. I had to ZIP the file because the forum won't accept PDF files for upload. If it doesn't work, my e-mail address is:
[email protected]
Just send me your e-mail, and I'll send you the file...
Sask32TL is offline
Old 08-15-2003, 02:49 PM
  #60
Registered Member
Thanks a lot bud. The zip file worked great. I really appreciate it.
khalils is offline
Old 08-16-2003, 01:11 AM
  #61
Registered Member
Sask32TL's Avatar
No problem (especially since I have NO LIFE WHATSOEVER, I have lots of time for stuff like this)
Sask32TL is offline
Old 12-01-2003, 04:17 PM
  #62
Registered Member
Ok i know no one has posted here in awhile and its sorta dead, but i have just recently read up on the whole dx6 project because i am looking for a cheap and easy upgrade to my tl. I just have a few questions.
If you are upgrading all four speakers, i have read somewhere that the volume has a drastic loss therefore you need to add an extra amp to boost the power and then bypass the eq. If you are bypassing the eq, then from my understanding your not using it anymore, therefor you don;t really have to get the polk dx6, you can really get any speaker that you can get to fit. Am i correct?? Because in the first place the main reason the dx6 was chosen was because it went well with the way the eq ouputed the sound.
My second question would be, is taking apart the whole dash to get to the eq and radio a hard job for an amateur who really has no expeirence in taking apart cars.
Any help would be greatly appreciated. Thx a lot.
Pat
Patrick_149 is offline
Old 12-20-2003, 01:12 AM
  #63
Registered Member
DX6 project mods
Just getting around to doing something about the sound in my '02 TLS, and saw the DX6 project postings. Seems like just what I'm looking for, but the listed link doesn't bring it up. Mainly need to know about the highs attenuation and any impedance matching. Appreciate any help. Also, are DB650's interchangeable?
thsshadow is offline
Old 03-08-2004, 02:44 PM
  #64
Registered Member
How do I get the file?
Your link does not work. I would really like to take a look at your mods for my 2000 TL.
kevincamel is offline
Old 03-30-2004, 05:52 PM
  #65
Community Architect
robb m.
astro's Avatar
astro is offline
Old 11-02-2010, 04:43 PM
  #66
Registered Member
looks good
fst64_v8pwr is offline
Old 11-03-2010, 09:23 AM
  #67
Fearless DIY Guy
DeathMetal's Avatar
Seriously?
DeathMetal is offline
cycdaniel
02-26-2019 08:55 AM
Marcelechka
Home & Garden
108
04-03-2017 01:48 PM
tsx_boy
04-11-2016 08:05 PM
foxriderar77
04-05-2016 10:45 AM
09-14-2015 03:16 PM
Quick Reply: dx6 project
