Will '06-'07 transmission fit in '04 TL?????
My auto transmission just gave out. I found a 07 accord v6 trans with good miles for 800. My question is will it work for my 04 tl and is it easy swap with out mods???? If anyone can help i would appreciate the help im suck and need my car back on the road.
Accord tran won't work on the TL because TL has SS mode while Accord just a regular AT with no SS mode.
(Post 13937090)
it will work i was about to do the same for my 2nd gen tl type s when mines was done but i sold it instead.......just the gear ratios are a little different......shouldnt have ni problem from where i see
Ive seen it done on the 2g....have yet to hear about it on the 3g
Well just bought the accord trans today so will be in by weekend. I hope everything goes smooth. Ill keep yall updated..... I guess ill be the first on here with a 3 gen with 06-07 accord trans..... Hope it works its alot cheaper then tl trans and from what I read has no problems..
This will be interesting .....
well then let us know how it gona turn out and don't forget to post any mod need to be bolt onto the TL.
yea good luck let us kno how it goes.....and yea tht yr trans is alot more reliable
when I swap it in I will keep you guys updated........... Ill have it in by weekend didn't have a chance to mess with it today... Also have to get new seals and get trans fluid...
Also what trans fluid should I use???? I've used amsoil but its hard to get it my way with out ordering it so any kind that would be easy to get? |
just use dealer dtw 1 atf i believe??? bought right from the dealer
Originally Posted by poody
(Post 13936886)
I would be wary of the accord as the accord has less power than the TL and perhaps lighter duty components.
Originally Posted by wojo1988
(Post 13942328)
(Post 13942283)
Installed trans today... I will finish up tomorrow and let you guys know how it drives. The trans was almost identical to a tl. The only thing I had to swap was range sensor mini harness. The plug on harness that plugs to tl harness was a little different but where it plugs to range sensor was the same. So just swap harness and thats the only difference.
hopefully thats the only difference and when you start the car it runs and shifts properly! well done
ok guys finished trans job today!!!!!!!!!!! Im so happy with the results trans shifts so smooth and ss mode works great. Everything was the same minus mini jumper harness that you just swap out. So if anyone needs a auto trans you now have the option to get 06-07 accord trans for your 3gen tl.
(Post 13937090)
stupid 04 Tls only accept tranny from 04. i tried to get a new one when my tranny blew but it wont work. you have to either get and 04 tranny or swap to manual. goodl uck finding the part for that tho
^? OP's vehicle is an 04? what r u talking about?
Originally Posted by pohljm
(Post 13955399)
Poody did you take any pictures ? So all of the transmission mounting are the same? This is good to know. Give us a long term report after you run many thousands of miles.
I'm about to do this swap in a few weeks for my wife's 02 TL-S .
She's on the second AT that was swapped out by Acura under warranty at 107k miles. Funny part is that she's only put less than 25k miles on the new Acura transmission and it's starting to have the 3rd Gear shudder under moderate acceleration or while going up hills. Quick question: Is it any 06-07 AV6 Transmission that will be compatible? Coupe or sedan alike? |
Subscribed... Waiting for pics and long term report.
awesome, I am glad it work out for you BTW did you did the 3rd and 4th pressure switch while the trany was out?
Originally Posted by mindanaomoro
(Post 13955932)
(Post 13956084)
Originally Posted by dirtyMETHOD
(Post 13956060)
Reviving an old thread for a status update.
Also can you explain the below statement further? Did you buy a new range sensor harness from Honda or was this something that came with the new Accord tranny?
(Post 13952475)
Originally Posted by lost
(Post 14864266)
Also can you explain the below statement further? Did you buy a new range sensor harness from Honda or was this something that came with the new Accord tranny? |
Is any of this info from the OP true about the Accord trans fitting a 3rd Gen TL? He never posted any pics or udates after 150 miles!
I think he put at least 10k miles minimum, then I think he had other/issues.
I have done this swap in my 2000 and now have 25000 miles on the swap. There is another second gen member with around 50000 on his second gen. I know a person that swap the av6 transmission into his 05 tl and he is probably around 15-20k miles in his with no issues
Any updates on this??? I'm looking at either rebuilding my tranny in the '04 TL or swapping out for the 06-07 AV6 tranny. Any updates or advice are greatly appreciated!
If you have the early 04 tran I would get a good reliable 06 tranny cause it would have the updated casing for better fluid channeling for lube and better "cooling" supposedly. The early 04 trans had that oil jet retrofit thingy.
Originally Posted by Stephen00TL
(Post 14868244)
my 04 tl is starting to slip and found an 05 tl transmission. Will this fit on my 04? Please get back to me
(Post 15671658)
Did you read this thread? Are you sure you want to throw in an 05 that may fail as well?
Just have it rebuild, I'm sure by now many updated clutch material and etc... And rebuild process are available. |
(Post 15671667)
Exactly! C'mom from 2005? You're gambling on the loosing end.
Just have it rebuild, I'm sure by now many updated clutch material and etc... And rebuild process are available. HONDA '05 BAYA MAYA & ACURA 04-06 BDGA TRANSMISSION REBUILD KIT WITH RAYBESTOS GPX FRICTION CLUTCHES - The American Powertrain Warehouse Also a high stall torque converter built by IPT performance would probably be beneficial. They're the ones that did Libert's TC on his turbo 5AT TL. |
Cool
Thanks Good info |
Need help got a 05 TL base transmission went out need to find cheaper transmission that will fit and work good
