When turning key, nothing happens
For all of you that have a 2004-2008 Acura TL and you experience issues with starting it from time to time,and you don't hear a crank, your first culprit would be looking at your positive battery cable and then your starter. For me, I would get all power to all accessories and when I went to turn the key, i would only hear a single click. this issue began to happen a few months after I bought the car and got seemingly worse after owning it for a while. I eventually replaced my starter and my battery cables and since then, I have had no issues starting it up. just wanted to share in case anyone is experiancing a similar problem! cheers
DMZ (07-17-2017)
thank you we are grateful
Head a da Family
thanks for the replies guys!
no problem man! I am the kind of guy who always takes to the internet to research when I have car trouble. I was unable to find any forums that gave a straight forward, concise solution to the whole "turning the key and hearing nothing but a single click" issue. it's maddening to scroll through multiple forums all similar to your issue, and none of them have a real solution to the issue. I feel like most people get their car fixed and then don't post the solution!
no problem! I had the "check starting system" warning as well, only a few times, but it did display. normally after it would fail to crank about 3 times the message would show and then it would start.. was definitely the starter! I recommend going to your local auto parts store (I went to autozone) and looking for the Mitsubishi reman.. It's top notch and it's actually the OEM starter for our make/model/year. After the install, my car sounded like a brand new luxury vehicle when firing up! I hope your issue is resolved with the help of this post because I spent a lot of time researching and didn't get any real answers.
