What's the mileage on your 3G? Still going strong?
Old 02-21-2013, 01:30 PM
  #401
Tony M
tony.m's Avatar
I have a 2004 TL 6MT with 245k miles on it.
The car will last as longs as its properly maintained.
So far i've done the following in no particular order:
1- Changed the spark plugs twice. The first time one of the spark plugs wasn't in tight and it exploded. That was an unfortunate event which caused damage to the cylinder head threads. Helicoil did the trick however every spark plug replacement comes with stress. This shouldn't have happened.
2- Multiple brake pad/rotor replacements. The Brembo pads wear quickly.
3- 1 Front caliper replacement.
4- Replaced two sets of rear brake calipers (sticky calipers; heavy corrosion caused by the New England weather).
5- Power Steering pump replacement. I'm experiencing issues again but I've managed to just deal with it until it completely fails.
6- Navi DVD player failed. Sent to Panasonic for repairs instead of paying an arm and a leg for dealer replacement.
7- Two timing belt changes.
8- Two clutch replacements. The first I had replaced at the dealer and the second I decided to replace it on my own. I replaced the second clutch over the weekend... Took 3 days and is labor intensive but saved me about $2000.
9- A few interior fuses.
10- Two rear wheel hubs.
11- Front and rear bushings.
12-Driver's side tie rod.
13- Front axles replaced.
14- O2 sensors (currently having an issue with the catalytic converter rear bank sensors... tough to replace, and so I'm dealing with it until I need to re-inspect the vehicle).
15- Car is consuming about 1.5 quarts of oil every 1500 miles. Slow leak in the rear main seal and probably losing some through the valve seals.
16- Replaced all coil packs.
The repairs pile on, however if you want to keep any car... you'll need to keep up with it. In all honestly the car looks great and doesn't feel like a car with over 200k miles on it.
Old 02-21-2013, 03:21 PM
  #402
One on the right for me
subinf's Avatar
Good to hear.
Old 02-21-2013, 04:13 PM
  #403
slcxow's Avatar
2005 nbp 52,450
Old 02-21-2013, 04:59 PM
  #404
qique516's Avatar
Hey everyone new to this site, my 08 TL just hit 28,500 miles.
Old 02-21-2013, 08:49 PM
  #405
wisekid's Avatar
Recently bought 2006 Tl with Nav 35000 miles.
Old 02-23-2013, 04:48 PM
  #406
Soltex05's Avatar
have a 05 tl
bought in 09 march with 64000 miles on it.
current mileage as of 2/22/12 75000
In 4 years i put less 11000 miles on it WOW...
Old 02-25-2013, 08:19 AM
  #407
june_june_0912's Avatar
a strong 51,000 miles...wooottt...
Originally Posted by main_shoby
i was being a little curious about my 2004 acura TL, i bought the car regardless of 144k miles she had. car is absolute beauty and extra clean.
I know 3g TL has a strong engine while accords go 200k easily, they should go a little more.
my question to all prestige 3g owners is, how many miles you have on your TL, what year and how good she runs now?
If there is no bad luck failure in car, on what kind of maintenance should i keep my eye on, in order to get her to 200k+ ?
i drive about 10-12k a year lol .. so ill get 210k in about 2017
Old 02-26-2013, 03:21 PM
  #408
Dubs_0's Avatar
05 at, bought with 84, i have 94 now.
Old 02-26-2013, 05:30 PM
  #409
carz0159's Avatar
my 04 AT has 121k, bought it new almost 9 yrs ago.
Still runs strong-ish, the engine is great, but the Transmissions makes clunking noises when it goes from P to R, D, etc.
Normal Maintanence:
Timing Belt
Oil Changes, etc.
Bad Luck Crap...
car went through 5 batteries
starter motor
knocker sensor
motor mount replacement... multiple times
maybe some more, just be careful, once the miles rack up...
I used to driver her 20,000 miles a year, now, probably alot less, around 6-10k
Old 02-26-2013, 06:34 PM
  #410
Umpire #27
salgiaco's Avatar
I am interested in buying a 2008TL with low miles. If you consider selling it, please contact Sal @ 586-530-6795 or email me @ salgiaco@sbcglobal.net
Old 02-27-2013, 07:28 PM
  #411
Lennox's Avatar
2006 today its 55,555
Old 02-27-2013, 07:32 PM
  #412
ArthurL's Avatar
Originally Posted by demarco5
Why don't you look into an extended 3rd party warranty. I just pay $50 copay and it's identical to the original warranty when it was new. New power steering pump, lines, starter, new front axle and boots. All for $50!
Easycare. And it's transferable for $50 so it's a huge selling point as well, assuming you want to sell down the road.
And.. what's this 3rd party warranty you're speaking about?
Old 02-27-2013, 07:47 PM
  #413
performace tl-s
rubenders's Avatar
07 type s 100k. Doing the 105 service this weekend. Extended warranty 3rd party. Power steering pomp replace engine oil pomp eginen mount replace for 100$ deductible.
Old 03-01-2013, 11:03 AM
  #414
tropwes's Avatar
My TL just turned 322K miles and I had the Flashing Engine light come on. I am the original owner on this 3G and have had it since January, 2004. She has been to Illinois, Florida, New Hampshire and everywhere in between far too many times to count. New York City and Philadelphia frequently as well. This has been an ultra low cost car to own and this engine fix as well. $302 after tax and diag to replace Cylinder 2 coil and plug. I have done multiple trans fluid exchanges (at home fashion) and only use Amsoil for the trans and engine oil. I only did spark plugs once and have done the timing belt twice at 140K and 270K. The seats have cracked from long term wear and a lack of conditioning and care on my part. Sad really because otherwise, no one would ever believe it even had 100k on it.
Old 03-01-2013, 11:47 AM
  #415
3g_ace's Avatar
Not sure if I can impress after a 320K. Impressive
04 TL 2nd owner 178k
So far I have replaced struts @150k
All 100k service completed (Previous owner replaced every fluid EXCEPT transmission fluid )
Transmission at 165k /Oil pan gasket
Valve adjustment @ 170k/Valve cover gaskets
Doesn't leak a drop of anything--my favorite part
Actually at a shop right now getting cam bolts replaced in rear.
Great car, not concerned about it lasting another 178k
jammoye2 (03-30-2013)
Old 03-01-2013, 04:50 PM
  #416
Dru111885's Avatar
06 TL 6MT 63k miles
Love every mile I add to her total!
Old 03-01-2013, 11:55 PM
  #417
subinf's Avatar
Jesus over 300k is impressive. I hit 191k today
Old 03-01-2013, 11:57 PM
  #418
main_shoby's Avatar
i got 169k now with my 04 TL.. i changed both front suspension assemblies, bought 4 new tires *used 40% of them" no engine light no shifting issues, did nothing but detailed the car.. it looks excellent! I got a cracked dashboard, so i placed a rag on it.
the only annoying issue i have is, my car pulls a little to passenger side (on all roads) its always the passenger side. Even after buying new tires, going to a chasis shop, rotation every 2-3 months, my car pulls towards pass side. I learned to live with it, besides that everything works perfectly
oh, i changed 3rd and 4th gear pressure switches and did a 3x3 atf change.
9632tl (03-10-2013)
Old 03-09-2013, 09:21 PM
  #419
NC State 05 TL NBP
mglum's Avatar
05 TL with 126k. I bought it at 35k back in Jan 09. I have been on countless long-distance drives; NC to FL about a dozen times, NC to WA and back. I guess my car is an interstate cruiser haha. I've done regular maintenance myself and have experienced no major mechanical issues. However, my navigation started the dreaded "please check your disc" bs at about 110k; the HFL went out soon after. I've been questioning the longevity of the electronics in this car but I think the engine and transmission still feel new. I'm thinking I can get 250k fairly easily.
Old 03-09-2013, 10:41 PM
  #420
6th Gear
Jefferson Vuong's Avatar
it's great to hear about all these cars with a lot of miles. i'm hoping my 08 tl-s lasts till 200k miles. it's at 75 now
Old 03-10-2013, 04:29 PM
  #421
2007 6SMT Type-S
SurfingScotty's Avatar
93,000 miles. "Check VSC" at 66,000 miles (failed TPBS part), CV boots click, rear suspension noisy/rattling over uneven roads, starter failed at 70,000, clutch began slipping at 80,000, "Tighten fuel cap" message weekly starting at 75,000 miles, and failed DVD drive for navi at 84,000. Numerous clicks and rattles.
I've spent more on repairs on my '07 TL in 3 years and 90,000 miles than I did in my 1st gen TL in 13 years and with more than 180,000 miles. Assembled in USA=FAIL!
Old 03-11-2013, 12:59 AM
  #422
kpc2593's Avatar
Just hit 112k miles on my 2005 TL Navi AT. Did the timing at 105k. Changed tranny fluid at 100k. Tires changed twice, brakes were done at 105k. Power steering pump is leaking but nothing major. HFL went out at 102k miles. Other than that this car is running strong!
Old 03-11-2013, 09:16 AM
  #423
MMkay.
Project_CLean's Avatar
i just hit 100k.2nd owner-
basic maintenance,replaced all suspension bushings just as preventive maintenance,especially since they are prone to failing (especially compliance and rear toe arms).
Old 03-11-2013, 09:47 AM
  #424
RaviNJCLs's Avatar
Originally Posted by RaviNJCLs
That poor car needs to be driven.
Tomorrow I'll pass 139K.
141550 now.
Only drove 2500 miles or so in the last month. Slow month for me.
Old 03-11-2013, 04:59 PM
  #425
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
I just hit 168K this morning
Old 03-11-2013, 09:35 PM
  #426
RaviNJCLs's Avatar
I'll try to catch you by the end of the year.
Old 03-11-2013, 09:41 PM
  #427
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
322k and the original owner? Damn tropwes
Old 03-11-2013, 11:27 PM
  #428
bahasad's Avatar
wow and I thought I had high mileage.
2004 AT. 136xxx, drove nearly 10K in the 7 months i've owned it. Right now it needs: new tires, brakes sometime in the future, bushings, and 1 bent rim. Nothing major. Oh and a dent on the door.
Old 03-12-2013, 03:41 PM
  #429
6th Gear
zetachi's Avatar
New to the forum. I've got an 04 TL with 35K. It was an inherited car from my parents. Was only used @ 6mths a year for the 1st 3 yrs (they were snow birds). For the next 3-4 yrs it was hardly driven (2nd car) and i didn't drive to work. Over the last 2 years I have been driving it to work.
Old 03-12-2013, 04:21 PM
  #430
08 MDX, 04 TL (sold)
jhumbo's Avatar
192k on mine. Got my car appraised by a used car dealer today. They offered me $4200 for it. He said it was the nicest 192k mile car he's ever seen.
Old 03-12-2013, 06:23 PM
  #431
Registered VTEC junkie
jchcmax's Avatar
2005 TL, purchased Janurary 2005. I just surpassed 55,555 miles on the freeway yesterday. So far the problems I encountered are : Driver side window motor failed, fixed under warranty. Bad driver seatbelt connection resulting in SRS light, fixed under warranty. Stupid Hands Free Link failed, draining my battery when parked. I just detached it. I never use it anyway and I don't have navigation. Other than that, she's still going strong.
Old 05-27-2013, 09:52 PM
  #432
bahasad's Avatar
Update
Originally Posted by bahasad
Just bought my 04 ABP TL on Friday. 125K miles, one owner, maintenance like clockwork. Can't tell how satisfied and happy I am - car runs super, nothing wrong everything in great shape. I'm very gentle with it though, light throttle always!
Hoping to run it till at least 200K, although I should have another TL by then .
Thought I'd bring this thread back to life with an update.
My car rolled over to 140K over the Memorial Day Weekend. I was debating trading the car in for a BMW E90, but because of the pathetic trade in value and the fact that this car has no outstanding issues, I have decided to keep it for one more year.
My maintenance so far:
- 3 oil changes
- ATF fluid change at 130K (hoping to do another at 145K)
- Just recently replaced the compliance bushings - totally changed the stability and handling improved
- Fixed up the paint (numerous scratches and dents/dings)
- Fixed a bent rim
- Bought new Hankook tires this weekend.
Overall, the car has been very reliable, and I like driving it. Love the engine, looks, interior, and gas mileage. Handling leaves much to be desired, imo, which is why I was considering going back to BMW, but I'm hoping to solve that with the tires and suspension.
My mods to be installed soon:
- Tein H-tech springs
- Acura A-spec front lip kit, rear spoiler
- (Big maybe) Rear sway bar.
Some pics:
Old 05-27-2013, 10:34 PM
  #433
ReDevil
r3devi7's Avatar
2004 Tsx 6mt 146000 (AC and Radio lights failed, all fixed now)
2004 TL Base 5at 54000 (Rear pass window weather striping peeled off)
2008 TL-S 6mt 64100 (No issues)
Old 05-27-2013, 11:20 PM
  #434
subinf's Avatar
198k now. Engine light goes on for about a day every few weeks. Did pads and rotors again.
Old 05-28-2013, 09:32 AM
  #435
Ak Ting Up
AcuraVic's Avatar
Update....
214K now, still running great, looking great, 9 years and counting...
Even after 9 years strangers of all walks comment on how "beautiful" she is.
I'm running synthetic tranny fluid (Redline) and syn oil (Mobile 1), for the last 4 years.
Old 05-29-2013, 12:16 PM
  #436
swoosh's Avatar
170K
and took a video this go around:
  #437
Cruiser
antlive's Avatar
Posted in a separate thread, just went over 200k, I'm at 200,246k Original owner...trying to get to 300k.
Old 05-29-2013, 12:18 PM
  #438
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
I wish you luck on your journey to 300k
Old 05-29-2013, 12:50 PM
  #439
2FRESHTL's Avatar
damn those alot of miles right there damn!!! 08 type s 23 k got it three months ago lovin it!!!
EmoneyRI (01-02-2014)
Old 05-29-2013, 01:20 PM
  #440
Wrong thread! haha, congrats on the "new" car though
swoosh (05-29-2013)
Quick Reply: What's the mileage on your 3G? Still going strong?
