What's the mileage on your 3G? Still going strong?
#361
For those of you with the 2004-2005 TLs and higher mileage (100k+) do you use the sport shift often?
I have a 2004 and try to limit how much I use sport shift to save the tranny. Just wondering if anyone else does this, or how often you all use sport shift.
Thanks!
Thanks!
#362
Sport shift by itself won't affect trans life. Avoiding the automatic 4-2 downshift will save lots of wear on the 3rd gear clutches as will replacing the pressure switches every 2-3 years and running a DexIII equivalent fluid.
#365
#366
If you're rolling along at light throttle and moderate speed, say 40mph you'll probably be in 4th. Punch it and it's probably going to hit 2nd. When this happens it briefly energizes the 3rd gear circuit and there's not enough exhaust capacity to release the 3rd clutches before the 2nd gear clutches engage. 2nd gear has the mechanical advantage so those clutches lock in as they should, 3rd gear slips. The driver may or may not feel a quick forward lunge.
Avoid it by not being in 4th when it downshifts to 2nd either by manually shifting or by "driving around" the problem.
#367
takin care of Business in
Received 4,732 Likes
^^^ manual shifting FTW !!!
#371
Thanks!
Thanks!
#372
I have 168K on my 05 TL and I always use sport shift....I even shit down when am coming to a stop...
the only thing about shifting which I have heard is the 4-2 downshift....looks up IHC's explanation on that
#376
BANNED
07 TL-S, AT, just hit 57k, constantly using SS.
bought in june 2010 with 35k
#378
I like turtles
76k on mine....havent even broken the car in yet. Does the MID regulate tranny fluid and pressure switch changes? Or is that something I should just do at this point?
#379
BANNED
no way!
i gotta keep them miles down!
you'll just have to decide at which intervals you want to do the 1x3's and switches. i do a 1x3 every oil change, some may say its a waste, but i'd rather be safe than sorry and since i'm already down there doing the motor oil why not. i plan on doing my switches again before i reach 100k...so, at this rate, in the next 4-5 years.
#380
Thanks for posting SS usage. I think this is a great metric for all of us to track. If everyone can post that, it would be valuable information.
#381
05' 133K Amsoil ATF every other oil change
SS when drag racing off of traffic lights
otherwise casually fast driving (30 mph over speed limits )
second tranny, due to the failed stock ATF filter at 120K (way too much grief for $11 part)
#382
8th Gear
05 TL auto with 91K Miles on it. Had to change Oxygen Sensor - Check Engine Light reading. Other than that only regular maintenance. Two tires always wear out quicker ( alignment check, balance and rotate tires regularly)
#385
'06 5AT w/ ~122k miles. Occasional SportShift, also when I want to hold 4th gear when I'm not going to stay in 5th gear for a while, and to hold lower gears to drive "spirited" down curvy back roads.
#386
08 MDX, 04 TL (sold)
190k miles on mine. It no longer runs "like new". It now feels like a car with 50k miles. This vehicle has just been truly a beast and I am constantly impressed with how well it holds up.
#387
the overexplainer
#388
How often do you all use SportShift?
#390
Rarely. I only occasionally use it to downshift from 5th to 4th, but it is certainly not a daily thing or even a weekly thing. I'm still on the original trans by the way. Shifts smoothly and I have been using a cocktail of Redline oils (D4+Racing+LWR) in the trans for a few years now. Plenty of threads on that topic, but it certainly worked well for me.
mcmguti (02-18-2013)
#392
someday !!!
#393
Me too
#394
I wish your Trip computer read 117 instead of 119
#395
I would've done that but I totally forgot about it
Was waiting for my brother, and saw it the last minute
#396
dont make excuses young man....
go to your room and think about what you did....
#397
07 TL-S, just turned 52k miles. I rarely use SS, I am used to driving stick, so when I go to use SS I can't help but lift my foot from the gas pedal when I shift. Makes for some odd reactions from the car!
