What the hell is this cable for!!??
Old 05-19-2017, 04:42 PM
Ibis's Avatar
Hey guys with the nice weather weve been having ive decided to clean my engine and sand some parts to be paint but ive notice this unplugged cable out of nowhere, im not sure if i accidently unplug it or it was always that way. Can you guys tell me what it is for? Thx plz no comment needed for the rust/dirt i bought the car that way and ive been trying since then to maintain and restore it.
Old 05-19-2017, 04:45 PM
Cold Business
SocomM4's Avatar
An amp?
Old 05-19-2017, 05:02 PM
wusty23jd's Avatar
Is there actually a wire within the wire loom? An amplifier cord would be a good guess.
Is there any kind of aftermarket switch in your cabin?
Old 05-19-2017, 06:43 PM
Received 8,575 Likes on 6,626 Posts
Amp would be best guess. I would guess headlight relay wiring but it looks like it's going into the cabin
Old 05-19-2017, 06:44 PM
Ibis's Avatar
Hey there is indeed a grey cable but i couldnt see it since it was so far inside the tube. Its grey and the end seem to have been cut. Any ideas what it is for and how to repair/change it? And also where does it go?? ty
Old 05-19-2017, 06:49 PM
Follow it
It's likely nothing now because it's cut. Just get rid of it
wusty23jd (05-20-2017)
jthiessens's Avatar
This could very well be a hood pin switch for a remote start disable also
Old 05-20-2017, 07:33 AM
Superunknown's Avatar
Pretty much only you can answer this, because it's not factory. None of us have it.
Old 05-20-2017, 08:52 AM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
^^^^ They're all liars, someone stole your flux capacitor!
Old 05-20-2017, 03:18 PM
Ibis's Avatar
Its driving me crazy everything on the car is working fine i do have a remote starter and the audio is good. Not sure what it could be i wonder how much the stealership will quote me the find whats its used for.
Old 05-20-2017, 03:33 PM
The following 2 users liked this post by thoiboi:
ABP UA6 (05-25-2017), wusty23jd (05-20-2017)
Old 05-20-2017, 04:32 PM
Ibis's Avatar
du ma 😉
Old 05-20-2017, 08:02 PM
wusty23jd's Avatar
Dude, just follow the cord to figure out what it connects to (which is likely nothing anymore). Bringing it to the dealership would be a waste of time and money.
Old 05-20-2017, 09:43 PM
jthiessens's Avatar
if you have a remote start and you car starts with the hood up (which it should not do) it's probably your hood pin switch. Easy way to test it is to start your car with the remote start then ground that wire out, it should stop the car. If it won't start with the hood up then it's not that but my money is on hood pin switch for remote start.
Ibis (05-23-2017)
Old 05-21-2017, 12:52 AM
Azine Jabroni
kurtatx's Avatar
Received 2,158 Likes on 1,386 Posts
That's no cable...it's a space station
The following 2 users liked this post by kurtatx:
ABP UA6 (05-25-2017), thoiboi (05-24-2017)
Old 05-25-2017, 11:39 PM
ABP UA6's Avatar
Just yank it REAL hard. I bet a balloon comes out of the trunk.
TacoBello (05-26-2017)
Old 05-26-2017, 12:45 PM
peter6's Avatar
Connect it to positive battery connection and look if something changed. If nothing happens connect it to negative. If still nothing just pull it really hard to see what's on the other end.
You could also try "smoke test" it. You will need extension cord and one wire. Connect cord plug to your house wall socket, on other side push this gray wire inside one hole, put short wire to the other hole and touch engine with it. Then you look for smoke, that makes it easier to find electronic component that was connected to it.
Old 05-26-2017, 12:47 PM
Old 05-26-2017, 12:52 PM
mazen222's Avatar
connect it to positive battery connection and look if something changed. If nothing happens connect it to negative. If still nothing just pull it really hard to see what's on the other end.
lol
Waffeey (06-13-2017)
Old 05-26-2017, 12:56 PM
mazen222's Avatar
Check out where this other similar one is going and see if there's something unplugged there. Or maybe that purple one in the circle was to replace the grey one?
But like others said, if it aint broke dont fix it... So if all your systems are working fine, just cap and stow it away.
Ibis (06-06-2017)
Old 05-29-2017, 01:25 AM
12volt's Avatar
Take it to a local car audio shop, they should be able to trace it down in minutes.
Old 05-29-2017, 11:48 PM
ABP UA6's Avatar
I still like my balloon idea...lol
Old 05-30-2017, 08:58 AM
mazen222's Avatar
I had a quick look at my car and looked like i had a very similar one going to the negative of the battery... Do you have two cables connected to your battery negative?
Old 05-30-2017, 11:41 AM
Cold Business
SocomM4's Avatar
There's 2 wires in that loom, grey, and the purple that switches looms near the strut bar. Where does the purple one go?
So , not an amp wire.
also, judging by the wire end, and the corrosion on it, it's been dead awhile.
Old 05-30-2017, 11:44 AM
Received 16,260 Likes on 11,971 Posts
didnt even see the purple wire switching looms, Good eye Socom!!!
Old 06-09-2017, 08:46 PM
Ibis's Avatar
We got a winner over here haha i was changing all my rusted bolts for new ones and painting the engine cover and strut bar. After removing the bottom right bolt(driver side) there was a small connector under it which was cut down as well. Im actually glad it was remove i often need to check the engine while it runs with the hood up! Thx anyway for all the replies and infos.
Old 06-10-2017, 09:01 AM
jthiessens's Avatar
