What happens if I don't replace timing belt at 105k?
Old 08-30-2012, 08:24 PM
  #41
bigshot82's Avatar
Originally Posted by RaviNJCLs
No one here can say for sure what will happen. I suspect that you will be fine but all I can really say is that you should do it as soon as possible.
Also keep in mind that cash may be tight but replacing an engine will hurt a lot more than finding the cash to pay for the service.
Where are you located?
Florida
Old 08-31-2012, 04:14 PM
  #42
Jackass's Avatar
$1300 and done in less than one day by the local Honda (Lee's Summit Honda) dealer. They said my side engine mount is shot, but they can't get the part directly and the local Acura dealer didn't stock it and would have to order it. So I ordered one from Delray today and will deal with that in a couple of weeks.
Old 03-02-2017, 05:30 PM
  #43
Tami Morrow's Avatar
Timing belt
Originally Posted by bigshot82
let's say do it at 110k instead? Finances are a bit tight and I don't want to shell out $1400 until I absolutely have to. DIY not an option.
2005TL
what happens if you don't replace timing belt on 2001 Acura TL
Old 03-02-2017, 05:37 PM
  #44
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
It's the same thing. Replace it, or risk it snapping. Will it snap at 106k? Doubtful. But it is climate based and usage based. No point putting off the inevitable. I highly doubt you'll see another timing belt change with that car, so just do it and forget about it.
Old 03-02-2017, 11:34 PM
  #45
treal512's Avatar
The planets will likely collide.
Old 03-03-2017, 09:46 AM
  #46
LeVeL's Avatar
2001 was the one year car where the timing belt needs to be replaced with every oil change
Old 03-05-2017, 09:55 AM
  #47
DMZ
Head a da Family
DMZ's Avatar
OP, where are you located?
Old 03-05-2017, 06:14 PM
  #48
chr1snyc's Avatar
Related question:
I'm having my timing belt service done on the side with a trusted mechanic for $350 flat on top of me buying the parts. If I decide to sell the car in the future, is there any way I can document proof of the job being done? It'll be easier for a possible buyer since the start of ownership in 2015 I've kept all normal service records and what not. I'll be keeping the receipt for when I buy the parts off of Amazon for a start. I'm asking out of curiosity. Thank you.
Old 03-08-2017, 03:42 PM
  #49
MikeTC's Avatar
You should have took a picture of your trusted mechanic while he was doing the job and signed the 'I did the TB' certification. Oh yea, your Amazon receipt should be fine as well.
Old 03-08-2017, 03:56 PM
  #50
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Old 03-09-2017, 06:15 AM
  #51
simplemonk's Avatar
Tried pushing it on an old BMW E30. When the belt snapped I had 7 bent valves, had to have the head redone. Forget the cable bill this month and Git 'er Done!!
Old 03-10-2017, 07:21 AM
  #52
Honda / Acura Fanboy
ReMiXeDg's Avatar
Originally Posted by chr1snyc
Related question:
I see you have NYC in your name. Are you located in NYC. I have a TL that needs same job done maybe we can go to that guy and you can get even more of a better price for yourself?
Feel free to message me and maybe we can both go to him if you don't mind. Thanks
Are you doing anything else other than the timing belt?
Old 03-10-2017, 08:24 AM
  #53
t-rd's Avatar
The timing belt will probably be fine, but it's the hydraulic tensioner that starts leaking, loosening the tensioner pulley, which causes the belt to skip teeth and cause a BOOM. Living outside of Chicago, my hydraulic tensioner actively leaked hydraulic fluid out one winter, down the side of the oil pan, which caused me to think I had an oil leak. This was 90k miles after running the last timing belt setup. This should give you an indication of failure times. I of course changed everything out after 100k miles. There is a clear documented case of belt valves from valves hitting top of pistons when the engine gets out of sync on a 07 Accord V6. The owner had to buy a used engine and do an engine swap.
Old 03-10-2017, 10:11 AM
  #54
Majofo's Avatar
Related question:
write your own receipt, take pictures
that's the homie price btw..
Old 03-10-2017, 12:12 PM
  #55
6spd-GERCO's Avatar
lol, don't replace it and report back when it lets go.
mada51589
05-03-2022 08:54 PM
IIDXholic
10-08-2015 07:53 AM
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: What happens if I don't replace timing belt at 105k?
