Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008)
Reload this Page >
We need a Definitive Timing Belt kit package number for all 3G TLS
Notices
Old 02-18-2013, 10:48 PM
2007 Type S WDP 5AT
wojo1988's Avatar
Liked 169 Times in 63 Posts
I have spent the last hour searching for a full timing belt kit for my 07 type s. I have not come to a conclusion on all of the parts yet. I know there is about 6 or 7 parts to the full kit including the tensioner and pulleys and water pump and belts. Can anyone help me out with every part im going to need to do a full TB service to my car this week??
Forgive me if I missed it and wasted time posting this thread, I was just unable to piece it all together.
wojo1988 is offline
Old 02-18-2013, 11:25 PM
Registered Member
Liked 74 Times in 59 Posts
for FULL, like full full timing belt job, you would be replacing pulleys but that'd be dumb.
there are many parts that some cars need and some cars don't such as oil seal which is rarely needed but since i just bought service manual like recently, i'm gonna look it up and list it for you
i did 1,2,3,4,5,10,11 and valve adjustment
1. belt(timing AND accessory. while you're in there)
2. water pump assembly
3. hydraulic adjuster (little piston looking? thingy)
* leave the car overnight to cool the engine completely, and valve adjustment. it's optional but everyone recommends it here.
----------optional--------------
4. hydraulic adjuster (tensioner) pulley
5. idler pulley
---------if needed-------------------
6. cam oil seals (front and back)
7. crank oil seal
8. camshaft pulley (ain't nobody ever need that at first timing belt service..)
9. etc. you won't know until the car's stripped apart.
now i did the accessory belt (not timing, the outside belt)
10. tensioner pulley
11. idler pulley
as well cuz well, they were kinda starting to squeak, and might as well while they tear that part apart.
4drviper is offline
Old 02-19-2013, 11:23 AM
Registered Member
Comptechtl2367's Avatar
Liked 85 Times in 77 Posts
I have never heard of anyone replacing the cam shaft pulley... Why would you need to do this?
Comptechtl2367 is offline
Old 02-19-2013, 11:24 AM
Registered Member
you wouldn't lol.
4drviper is offline
Old 02-19-2013, 11:29 AM
#1 Super Guy!
94eg!'s Avatar
Liked 496 Times in 358 Posts
It's called Gates brand TCKWP kit. Contains everything you need. The bonus is that every component in this kit is the exact same brand part as OEM/Acura, with the exception of the Water pump (Gates brand instead of Yamada). Yes it has Koyo rollers, Aisin hydraulic tensioner and Gates/Unitta timing belt just like the Honda box version of these same parts. Yes, Gates makes most of the timing belts for Honda. Especially the ones for their high-reving 4cyls.
For all 05-08 TL's with 3.2L or 3.5L it's TCKWP329. $159 @ RockAuto.com
If you want just the belt & rollers, order TCK329. $75 at RockAuto.com
If you want just the belt, order T329. $20 at RockAuto.com
94eg! is offline
The following 3 users liked this post by 94eg!:
GeeteeDan (02-19-2013), Undying Dreams (03-28-2013), wojo1988 (02-20-2013)
Old 02-20-2013, 08:49 PM
2007 Type S WDP 5AT
wojo1988's Avatar
^ thanks alot! So that has 1 Belt, 2 Tensioners, 1 Idler, 1 Water Pump. I just need to get the serpentine belt, thermostat, plugs and?? Just want to make sure im not missing anything at all. I appreciate all the help!
wojo1988 is offline
The following users liked this post: wojo1988
bluetl04 (02-21-2013)
Old 02-20-2013, 09:43 PM
#1 Super Guy!
94eg!'s Avatar
Get the Gates serpentine belt from RockAuto Along with that kit. You can always find -5% coupon codes for that site too.
OEM Plugs (NGK Laser Iridium) are cheapest at AdvancedAutoParts.com with coupon "CCABIN". Comes out to something like $45 shipped.
For thermostat, I would probably just buy from Honda (OEMAcuraParts.com)
94eg! is offline
The following users liked this post: 94eg!
Old 02-20-2013, 10:09 PM
paperboy42190's Avatar
Liked 1,149 Times in 838 Posts
^that is correct. you need auto tensioner, adjuster, idler pulley, water pump, and the timing belt. theres actually already a definitive list on the forum....I did my research when I had to do my timing belt job and found everything I need.
paperboy42190 is offline
The following users liked this post: paperboy42190
Old 02-21-2013, 09:35 AM
Registered Member
hofiveo's Avatar
Liked 37 Times in 26 Posts
Timing Belt - 14400-RCA-A01
Drive Belt - 3892-RCA-A03
Water Pump w/ gasket - 19200-RDV-J01
Timing Belt Adjuster - 14510-RCA-A01
Timing Belt Auto Tensioner - 14520-RCA-A01
Timing Belt Idler Pulley - 14550-RCA-A01
Thermostat w/ gasket - 19301-P(S or 8)E-A10
Cam and Crank seals, no # sorry.
Valve Cover Gaskets and Spark Plug Seals
hofiveo is offline
The following users liked this post: hofiveo
Old 02-21-2013, 10:05 AM
#1 Super Guy!
94eg!'s Avatar
Valve cover gaskets & spark plug seals, as well as spark plugs & even thermostat have nothing to do with changing the timing belt. None of those things need to be removed while you're in there. I'm confused on where this thread became about doing a valve clearance adjustment.
I wouldn't even consider the crank & cam seals part of this job, unless there was an existing leak.
- Cam seals: 91213-R70-A02
- Front Crank Seal: 91212-R70-A02
PS: Don't spend double the price on the exact same components from the dealer. Just get the Gates kit.
94eg! is offline
Old 02-21-2013, 06:51 PM
Registered Member
bluetl04's Avatar
Liked 138 Times in 120 Posts
This is some good information to know..Never knew Gates was the oem maker of our timing belt kit...Great job guys
bluetl04 is offline
Old 02-22-2013, 03:45 PM
2007 Type S WDP 5AT
wojo1988's Avatar
Ended up taking the tl into the dealer this morning to get it all done. Getting full timing belt done, valve adjustment, thermostat, broken engine mount, all 4 rotors replaced and full brake fluid flush for about 1400 otd after taxes and all
wojo1988 is offline
Old 02-22-2013, 04:44 PM
#1 Super Guy!
94eg!'s Avatar
$1400?!?!
94eg! is offline
Old 02-22-2013, 05:35 PM
Registered Member
callahan's Avatar
Liked 73 Times in 71 Posts
I'm sorry...
callahan is offline
Old 02-22-2013, 07:58 PM
2007 Type S WDP 5AT
wojo1988's Avatar
Welcome to Canada EH?
wojo1988 is offline
Old 02-22-2013, 10:25 PM
Registered Member
Pair of TLs's Avatar
Liked 36 Times in 34 Posts
Pair of TLs is offline
Old 03-28-2013, 03:14 PM
Registered Member
Liked 0 Times in 0 Posts
Water Pump w/ gasket - 19200-RDV-J01 (yamada)
Timing Belt Adjuster - 14510-RCA-A01 (koyo)
Timing Belt Auto Tensioner - 14520-RCA-A01 (aisin)
Timing Belt Idler Pulley - 14550-RCA-A01 (koyo)
Valve cover gasket 12341-rca-a01
Spark plug tube 12342-rye-004 (NOK)
mtxjohn is offline
Old 03-28-2013, 04:32 PM
TL-S
quanaman's Avatar
Liked 406 Times in 363 Posts
that actually isnt all that outrageous....Including all that brake work and what not at 1400$ is a decent deal IMO. I've seen some dealers ask for 1500+ for just the tb/wp job.
quanaman is offline
The following users liked this post: quanaman
TLtrigirl (03-28-2013)
Old 04-08-2019, 09:22 AM
1QWKTLS
Q_ShipTL's Avatar
Liked 11 Times in 10 Posts
I see its been a few years since anyone has posted on here, but since I just hit 100K on my TLS I've started to research t-belt service.
Ive looked up the Gates kit TCKWP, but it seems many people are claiming water pump failure in the first year!
[color=#555555 !important]March 12, 2018[/color]
[color=#c45500 !important]Verified Purchase[/color]At 15k after the replacement, the water pump has failed and leaked something fierce. Happened after warranty so no action other than to replace with Honda Genuine. Too bad, too. Gates was highly recommended by our mechanic.
Recommended by our mechanic as close to an OEM replacement. Works very well after 9k miles
1.0 out of 5 stars 1.0 out of 5 stars
Leaking water pump. Leaking water pump.
[color=#555555 !important]August 7, 2018[/color]
[color=#c45500 !important]Verified Purchase[/color]I always recommend my side jobs to buy either Gates or Aisin because of their OEM fitment, the fact that it comes with the idler pulleys and I’ve never had belt length issues, I found I had a coolant leak from behind the timing cover, come to find out it was from the water pump housing!! The o-ring was not cut, cracked, torn or pinched between the housing yet it still leaked! Looks like I’ll be buying Aisin from now on.
Has anyone on here had any sort of bad experiences with this kit? I may just order all the parts from Acura online just to play it safe.
Q_ShipTL is offline
Old 04-08-2019, 09:27 AM
1QWKTLS
Q_ShipTL's Avatar
Here is a clean parts list in case anyone else is interested in Acura OEM Parts:
1) Timing Belt: 14400-RCA-A01
2) Drive Belt: 3892-RCA-A03
3) Water Pump w/ Gasket: 19200-RDV-J01 (Yamada)
4) Timing Belt Adjuster: 14510-RCA-A01
5) Timing Belt Auto Tensioner: 14520-RCA-A01
6) Timing Belt Idler Pulley: 14550-RCA-A01 (Asin)
7) Thermostat w/ Gasket: 19301-P(S or 8) E-A10
8) Cam Seal: 91213-R70-A02
9) Front Crank Seal: 91212-R70-A02
10) Valve Cover Gaskets: 12341-rca-a01
11) Spark Plug Seals: 12342-RYE-004 (NOK)
12) Spark Plugs (NGK Laser Iridium)
Q_ShipTL is offline
Old 04-08-2019, 09:30 AM
Registered Member
Liked 459 Times in 395 Posts
Q_ShipTL, just take your car over to:
First Class Automotive
3608 E Colonial Dr, Orlando, FL 32803
(407) 228-2849
Talk to the owner Nabil, he will hook you up with the right service and parts for your Acura.
zeta is offline
Old 04-08-2019, 05:29 PM
Registered Member
nfnsquared's Avatar
Liked 1,539 Times in 1,157 Posts
1.0 out of 5 stars
Leaking water pump.[color=#555555 !important]August 7, 2018[/color]
[color=#c45500 !important]Verified Purchase[/color]I always recommend my side jobs to buy either Gates or Aisin because of their OEM fitment, the fact that it comes with the idler pulleys and Ive never had belt length issues, I found I had a coolant leak from behind the timing cover, come to find out it was from the water pump housing!! The o-ring was not cut, cracked, torn or pinched between the housing yet it still leaked! Looks like Ill be buying Aisin from now on.
I've installed 2 Gates kits (at 110K and 215K) with no issues. I'm at 310K now and will be installing my 3rd Gates kit late spring / early summer. I'm pretty sure those idiots over torqued the water pump bolts...
And you're aware of the epic TB thread started by his Majesty, Majofo?
nfnsquared is offline
The following users liked this post: nfnsquared
gatrhumpy (04-08-2019)
Old 04-09-2019, 12:57 PM
Registered Member
Aisin RockAuto
How is this even a question?aisin kit from RockAuto uses all OEM parts. the only thing that isn't OEM is the actual belt and that is an oem for Toyota.
mtxjohn is offline
merc009
21
09-14-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: We need a Definitive Timing Belt kit package number for all 3G TLS
