WDP TL Type S rear bumper paint not matching
Is this normal for all WDP UA7 ? I know that it's common for all cars to not have the bumper's paint match the body's under various light shade because of plastic vs metal. But on my specific car, it's very noticeable and it really seems like the bumper has been repainted and they did not choose the right and exact same color. I am planning to have the bumpers repainted to actually match the body as much as possible. Let me know your opinions all WDP owners out there!
https://flic.kr/p/nHQbwN
https://flic.kr/p/nKGa59
https://flic.kr/p/nKSArp
https://flic.kr/p/ntoq7v
I have the exact same issue with my Type-S. The previous owner had it repainted after it was damaged. I've called a few local body shops and have done a bunch of reading up on the issue and it turns out that tri-coat white pearl paints in general are very difficult to match.
The proper way to match the paint is to make a "let down" panel to find out how many coats of pearl to spray on top of the base coat so that it will match the rest of the body.
It appears with your car and mine that the body shops did not make a let down panel and sprayed on too many coats of pearl which leads to it looking slightly dark or more yellow.
Unfortunately the only way to fix the issue that I've found is to get the bumper repainted (after creating a let down panel to properly match the color).
petesbimmer (05-27-2014)
^Yup. OP, if you do a search you'll find that the white and silver have off color bumpers from the factory, actually in my mind inexcusable. If the front matches, then the front has been repainted and back OEM.
The wife hit a teenage deer years ago and needed a new front cover. After some test shots, they matched the WDP body paint perfectly. Just sorry I didn't spend the extra money to have the rear painted at the same time as it's still a thorn in my side when I see the difference in color.
As the powers to be didn't think it necessary to match bumpers, the 4G has the same off color bumpers.
Amazing how other manufacturing companies can match the pearl perfectly, not Honda.
I had a pearl white Lexus in the past
The paint needs to be blended into your quarters...more $
At least that's what my body shop did, and it came out perfect
Security Dude
Wow that's pretty bad, but very common in any car with specialized paint as time and the sun change the paint so getting it to match is super hard if not impossible. Like mentioned above blending to the quarter panel is the bes way to make it look better
weird that you have side A-spec but not rear or front.
Yea I definitely see most WDP TL TYPE S have their bumpers not perfectly matching their panels, but it seems like mine is worse cause it's prob has been repainted by someone who didn't do a job well done
That's what I'm saying.. I think mine is worse than other WDPs on this forum
That's because I was going to install the front and rear but my dad noticed a sharp pain in his eyes, as a painter, that the bumpers are discolored. So he decided to paint both the front and rear bumpers and will have the rest ASPEC kit on after!
Slpr04UA6 (05-27-2014)
no, yours looks about right. unless you went up close to other cars it's hard to tell the color mismatch. A lot of times when a car is dirty, it actually hides the paint a bit. When a car is at it's cleanest, that's when you'll see all the imperfections
shifting at 7k
My rear bumper is the exact same way. It's actually funny because when I installed my Type S A-Spec rear lip that was brand new, the lip matched the quarter panel but the bumper was still discoloured and yellowish looking. I think paint ages faster on plastic versus metal.
I like turtles
I only notice the issue in certain lighting. My front bumper was an issue too but I had that repainted once I removed the aspec kit (due to mismatching paint) and now it matches beautifully.
I love WDP but if I could do it all over again I would have went with any other color acura offered on this car.
silver is another one of those colors that is VERY tough to match
not as tough as Pearl White, but still tough...
the overexplainer
might just be me but in the OP's first picture it looks like the trunk and spoiler are also off white. It's pretty apparent comparing the top of the trunk and the quarter panel. The roof doesnt share the same shade.
Perhaps it was rear ended and repaired/repainted?
nanos
11-12-2015 08:41 PM
obsessedmotors
09-10-2015 10:49 AM
09-04-2015 08:03 AM
