VLEDS 6-LED 725 Lumen DRL 9005 bulb
These are 5k versions used with ijdmtoy drl harness. Full power and no "DRL" light on the dash
I took some pictures earlier today when I installed them but my micro sd card on my phone got damaged somehow and everything was reformatted (anyone know any good microSD card brands? I was using a 16gb sandisk class2 when this happened)
The only pictures I could get was at night so here they are. I was parked about 30-40 feet facing a wall when pictures were taken.
Req21 (04-06-2013)
Looks bright!
Can you take pictures during the daytime?
It's very bright. You can drive using the DRLs at night if your just driving down a small street. I'll try to get daytime pictures tomorrow. I'm so pissed I went to the aquarium and took lots of pictures and videos and after we left my phone says my MicroSD card is damaged and requires reformatting to be used.
Thanks they are super bright in person. It's not smart to look directly into them head on at night.
I don't see a point in having halos because I wouldn't use them during the day, and at night the xenons would just overpower the halos. It's more of a "for show" and "cool factor". We have dedicated DRLs and it's the bulb I'm using. BMW uses halos as their dedicated DRLs in some vehicles and/or with certain lighting packages.
Rev High; Drive Happy
Sandisk is usually good. I have a patriot 32gb class 10 and its given me 0 issues. Lexar is another to look into. Buy class 10 cards!! The speed is great
and damn that's bright for an l.e.d
HE>i
DONT use that memory card until you try the recovery software on it (usually comes with it). You can still save some of the pics, UNLESS you write over them. Sandisk is a great brand, and Transcend, and Lexar.
I will post more info on this later, Gotta go to work right now.
Interested in the daytime pictures too. I received my 6 LED bulbs this week and am debating whether to send them back for the 10 LED bulbs, which could be pushed back a few more months as these 6 LED bulbs were suppose to be available back in December.
I know most people are using the iJDMtoy kit, but has anybody tried the VLEDs DRL module that is suppose to provide full power to the bulbs? I'm guessing it will still throw a DRL error on the dash since it doesn't have the resistor.
HE>i
Back to what I was talking about...
If you formatted the card already, it doesnt fully erase the card(data is still stored on it). It rewrites the data as you take the pictures (eg: say you had 1000 pics, then card was corrupted, you wiped the card and started over taking 200 new pics. you may still be able to save the 800 pics that havent been wrote over)
I have been using Sandisk cards for forever now (2 16gb class 10's, and 3 8gb class 10's) without any problems. Not saying there are not any defective cards, but most of the time it can be user error (eg: installing/uninstalling card while the device is turned on)
I would suggest buying another memory card anyways, because you dont want that happening again.
This is about the 2nd or 3rd time I've had this problem with this SD card. It's definitely time for a upgrade to something better and more up-to-date.
Don't mind the paint chip. I need a new front bumper and paint job. That front bumper has so many problems that I would be better off buying a new bumper and getting it freshly painted.
guitarplayer16 (04-06-2013)
wow, looks good!
almost looks like jewel eye in the daytime pics...
and also try to run some recover software on the SD card. plug the card into the computer and run a program like recuva on it.
When it comes to SD cards, no one mentioned G.Skill was good or bad. According to newegg rating these seem to be a big hit.
What do you MicroSD card gurus think?
http://www.newegg.com/Product/Produc...82E16820231577
The V3s will be brighter than your DRLs.
Received 3,824 Likes
They look great! Anxious to see how the 10 LED bulbs turn out.
Honestly, it doesn't really matter. Most any brand will work fine, non-volatile SD memory is pretty reliable as long as you don't remove the card while it's busy transferring files or before telling the OS to safely remove it as that will or can lead to corruption. Your card might still be usable as well with a reformat. They can eventually develop bad cells over a long period of time though, they don't last forever.
NVM I see they are rated at 600 lumens in white (parking light mode) and 430 lumens for amber (turn signal mode). Hmmmm.. These DRLs are rated at 725 Lumens and also have a 850 Lumen version available. What do you mean that the tritons will be brighter than the DRLs? Is it because the tritons has the lens on it that makes the light output seem more intense and spread out?
Either way I need something brighter for my switchbacks. I'm currently using these 48 LED (24 white 24 amber) switchbacks in 5k I bought from VLEDs and they aren't cutting it lol.
http://www.vleds.com/bulb/7443-7440-...na-1-pair.html
The website spec says they are rated at a measly 96 Lumens. It doesn't specify if that's white or amber mode but I"m pretty sure that 96 lumens is for the white (parking light) mode. If that's the case, the amber mode is probably only around 50~ish lumens. That means those tritons are about 6x as bright as my current switchbacks! I want them! Just not for $134.99. I'll pay maybe half that lol
V3s are 600 lumens
Also anxious to see how the 10 LED turns out, too.
Undying Dreams (04-12-2013)
Wow how many Lumens are the v3 tritons rated?
vietxquangstah did you use DRL relay from VLeds to get full power?
I use my old ijdmtoy DRL decoder but it looks just like a resistor, but some people here call it decoder that gives full power to LED DRL. I wonder if the VLeds relay is the same
thats why I'm asking ijdm decoder doesn't look like Vleds relay box, yet ijdm decoder is rumored to give 100% power besides error free DRL. I am happy with mine but nothing to compare with
I was even going to buy the Vleds relay to see if there would be any difference but its out of stock now
I am shipping out my set via USPS priority mail tomorrow. I probably won't get the 10 XB LED versions until the 29th or 30th. If they ship out the same day they get my return item than I might have it as early as saturday the 27th..
Any of you guys got the 10XB versions yet or returned your 6 LED version for exchange yet?
Undying Dreams (04-22-2013)
So today I decided to remove my 6 XB LED bulbs to return them for an exchange to the 10 XB LED versions. I'm glad it was very easy removing the bulbs this time around compared to removing the stock halogens.
i just did my 3rd gear stock pull today so that we can look at stock fuel and ignition maps before starting the tune. i'm hoping to have my first calibration from him this weekend or so. PM me if you have any questions about it, i know there are a few other members who have started/finished tuning with vit and were very happy with it
2008 NBP TL Type S
I recently received my 10 LED DRL from V-Leds and I tried to install them earlier this afternoon and they won't turn on for me. I tried using the original relay harness from V-Led that I bought a couple years ago from them. I'm going to have to do some more troubleshooting apparently. Maybe I should buy a new relay from ijdmtoy and try that?
2008 NBP TL Type S
I should also mention that i'm a complete amateur when it comes to ANYTHING electrical and I am easily confused with this sh*t (I wish I had good directions or a DIY video). Can you provide me with the link for the relay harness from ijdm that you're currently using? Also, did all of you guys access the DRL from the engine bay or drop the bumper when hooking the DRL's up?
You can access the DRL from the engine bay.
So I sent my 6XB LED versions back and wrote on the RMA form that I am returning them to exchange for the newer 10 XB LED versions. I mailed them out Monday. On wednesday I got a e-mail from both paypal and VLEDs. Paypal said they refunded me money from VLEDs and the VLED e-mail said they credited my VLED account with $39 (I bought the bulbs $59.99 but had a 35% discount)
I was pretty mad and felt like I got tricked. I immediately e-mailed them back and got this response.
Sent: Friday, April 19, 2013 12:07 PM
Subject: RMA FORM
Hi Quang,
On your RMA return form, write down in the comments section you are returning the 6 XB LEDS in exchange for the 10 XB LEDS.
If you have any more questions please feel free to contact us and have a wonderful day.
Subject: RMA FORM
Hi Quang,
Sent: Wednesday, April 24, 2013 5:45 PM
To: sales@v-leds.com
Subject: Re: RMA FORM
So today I got a e-mail saying
VLEDS.COM: Credit Memo # 100000453 for Order # 100001284
Your Credit Memo #100000453 for Order #100001284
I was told that I would be automatically upgraded to the 10XB LED versions for free at absolutely no charge. It appears that all I got was a refund of what I paid for the bulb. A refund is not what I want. I stated that I wanted to exchange the 6XB for the newer 10XB versions.
I was expecting to send in my old bulbs and than get shipped new bulbs.
Hi Quang,
We apologize for the inconvenience as there was a mistake made in our returns department.
If you wish to order the correct part we will ship your order out immediately.
We do not keep your account information on file so we can’t charge your card and sent out another pair of LEDS.
Again we do apologize for this mistake, if you have any questions please feel free to contact us.
https://acurazine.com/forums/3g-tl-2004-2008-93/ijdmtoy-led-drl-harness-install-w-pics-853543/
As for reaching the DRL bulbs I simply reached them from the engine bay. You might have to contort your arm and wrist in weird positions and stand your body at awkward angles just to get the DRL bulbs out but that's better than dropping the bumper and removing the headlights. After doing it the first time, it now only takes me 5 minutes to remove both DRLs.
The first time you try to remove your factory DRLs it will be a bitch. They seem nearly locked in place. I spent easily 10-15 minutes trying to remove the driver side alone the first time around. After that it's cake.
